BAP, which one? MDS or KB?
It kicks up the voltage going to the fuel pump, giving you a bit more fuel delivery with the same pump. (or letting you get the full advertised delivery by making sure you get enough voltage)
The KB (Kenne Bell) unit has an adjustable **** you mount near the driver to adjust it on the fly if you want. It also comes with an optional boost/nitrous switch to kick it up only on demand.
I was seeing around 10.5 volts at the pump without it.
Which of the casper volt boosters are a direct fit to our cars? I assume the 98 to what ever year GTP but just wanted to douple check. Definatly a great deal for around $80.
Thanks,
Dave
call to make sure.
i have bs3 logs that show at 80% tps my ignition voltage increases the claimed 2 volts and stays there... works for me
call to make sure.
Later,
Dave
How about one for each cylinder.
........... I would just like to know if there are other ones out there, to compare with as well.As for the voltage booster I emailed caspers the other day and the correct
P/N for current LS1 is 102130 98-02
