New Numbers
Old Jan 15, 2006 | 09:39 PM
Slowhawk's Avatar
LS1Tech Sponsor
I'm alittle surprised it's only hitting low 500's with your setup and 10lbs.Timing set low for the juice?Compression too low?
We have a 9,5-1 402 doing 569rwhp with the 4.0 pulley -4lbs of boost. Just put on a 3.4" pulley and will be dynoing it tomorrow
Old Jan 15, 2006 | 09:46 PM
Ed Blown Vert's Avatar
Me too, I thought I would be in the high 500.
CR is 9.0 with 18*-20* of timing. Once I get the AFR leaned out a bit, I will play with the timing some more.
Old Jan 15, 2006 | 10:00 PM
blackz93's Avatar
Originally Posted by Ed Blown Vert
My new numbers. Looks like I maxed the P1
I've seen the P1 make close to that without nitrous. I doubt it's maxed out!
Old Jan 15, 2006 | 10:13 PM
I can't spin it anymore than I am now.
Old Jan 16, 2006 | 03:06 PM
Slowhawk's Avatar
LS1Tech Sponsor
FYI -dyno'd the car today and it put out 620hp580tq SAE.It has a 3.4 pulley.Hit 500hp at 4500rpm.Boost hit 9.5lbs
SPEC
402LS2 at 9.5-1 comp.
AFR 225 heads
232/238 with .590/.590 lift on 115 dur.
Kook stepped headers
Cutout
9" with 3.73 gears .locker
M6
Timing at 22 degree's from 2200 to 3800rpm, 20deg at 4000rpm,18degree at 4400rpm,then 16 degree on the rest. A/F was at 11.2-1 across the board.
Just to give you an idea
Old Jan 16, 2006 | 03:21 PM
ddnspider's Avatar
But that setup has more compression,more displacement,bigger cam,and is a stick.....
Old Jan 16, 2006 | 03:48 PM
I would be happy with those numbers.
I don't think a half point on CR would make that much of a difference.
The only other thing is the heads. They were Absolute Heads and we know he went out of business.
And I do lock the converter on the dyno.
SPEC
AFR 225 heads
Cutout
M6
Old Jan 16, 2006 | 03:59 PM
ChevyNo1's Avatar
Originally Posted by Frost
666 !!!!
evil engine !!!!!
LOL, I can't believe it took that long for someone to say something. And it was 666 on the dot too! Nice #'s!!
- Dug
Old Jan 16, 2006 | 05:14 PM
Slowhawk's Avatar
LS1Tech Sponsor
Yes,just a reference.
BTW-3 of my 346's push more HP than this 402 with smaller heads and Cam,so cubes don't make that much of a difference
