Meth VS IC
Old Jan 16, 2006 | 04:19 PM
fastlt1's Avatar
Default Meth VS IC
Why run an intercooler if you are planning to run a alky kit too???
Old Jan 16, 2006 | 04:33 PM
Wnts2Go10O's Avatar
the cooler the charge, the more timing that can be run, the more power you make.
Old Jan 16, 2006 | 05:06 PM
Rocket468's Avatar
I am pretty familar with alky Alky is great for pulling heat out of the air but it does have limits. Having both would be ideal.
Old Jan 16, 2006 | 05:13 PM
SuperZ's Avatar
Yes do both
Old Jan 16, 2006 | 05:15 PM
fastlt1's Avatar
How much boost could you run on straight met alone?
Old Jan 16, 2006 | 05:17 PM
grb's Avatar
grb
Both keep you off race gas.
Old Jan 16, 2006 | 05:21 PM
fastlt1's Avatar
4-5 # w/o intercooler
7-8 # w intercooler
??? # w IC & Meth
??? # w IC, Meth, & 100 octane
Old Jan 16, 2006 | 06:17 PM
HUGGER ORANGE SS's Avatar
7-8 # w intercooler
??? # w IC & Meth
Where did you come up with these figures..
I'm running 13 to 14psi w/o Meth on my Dual Intercooler setup..
No KR for me.. 20 deg of timing.. and 91 to 93.5 oct Gas
You can run more boost than 4 to 5 psi W/O the IC just lower your timing tables..
clint
Old Jan 16, 2006 | 06:18 PM
cablebandit's Avatar
with no intercooler and meth + 93 i can run 15 psi at 15 deg timing in the cool air
intercooler and meth 15psi and 20 deg of timing (intercoolers are way past efficiency)
Old Jan 16, 2006 | 06:20 PM
fastlt1's Avatar
What is your CR??
Old Jan 17, 2006 | 08:04 AM
346 with 9:1 pistons and #317 heads so i'd guess 8.8:1
Old Jan 17, 2006 | 10:18 AM
I'm running 9.4 CR myself..
Old Jan 17, 2006 | 10:29 AM
TrakDay's Avatar
On the Stock Bottom End and Cast Heads with only valvetrain upgrades
I was running 8psi and getting a touch of knock up top so we backed down on my GTO. The car was making 550rwhp and does have a single IC that came with my Procharger.
Now I run 11psi with methanol and get no knock all the way up to 603rwhp. I am quite happy I put methanol on my car.
I went from 11psi with no methanol and only making 570ish rwhp to adding the methanol and making over 615 on my best hotlapped pass on the dyno! I talked to my tuner and decided I wanted it to be safer than that so we pulled a degree of timing and ended up just over 600rwhp!
Methanol is one of the better things I have done for my setup. Wish I would have done it when I was running 8psi so I had another comparison for you!
