Master Power turbos
Old Jan 20, 2006 | 05:28 PM
whynot's Avatar
so if the t3 flange is chokeing it out, then why does your site say it is good for 800 hp, which would be over 650 rwhp.
Old Jan 20, 2006 | 05:39 PM
Project GatTagO's Avatar
Because the compressor is what determines the HP rating. So on a smaller displacement engine the T3 exhaust housing may work just fine.
Andrew
Old Jan 20, 2006 | 05:45 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Andrew
Its all about pressure ratios. A turbo can be rated 20000hp, but if the pressure ratio forces the turbo to run outside its efficient range you will never see anything close to it.
Jose
Old Jan 21, 2006 | 01:35 PM
TX RED's Avatar
thanks for your help jose can u pm on some pricing on that gt42
