PTK results.
Old Jan 17, 2006 | 08:22 PM
onfire's Avatar
Coal Mining Director
An electronic controller (EB2) will not let you run boost lower than the preset on the wastegate. It will let you program how much more boost you want beyond the gate.
Old Jan 17, 2006 | 09:00 PM
nossty1's Avatar
Thanks for clearing that up for me onfire. The main problem is that the car is making boost to early(2000rpms) That is extremly low for that kind of boost. Also the car is sputtering like the spark is blown out or something when the boost comes on, but only when the car has load like on the dyno. It doesnt sputter on the street when it just spins the tires.
Old Jan 17, 2006 | 09:34 PM
Frost's Avatar
What plugs & gap?
Old Jan 17, 2006 | 10:10 PM
nossty1's Avatar
I believe they are tr6. Not sure of the gap but I was told to tell them 30 thousandths
Old Jan 18, 2006 | 05:02 AM
smokinHawk's Avatar
what exhaust housing do you have with your T70?
id hope its a .96 AR, if its smaller maybe thats your problem.
Old Jan 18, 2006 | 08:40 AM
SUPER DAVES Z's Avatar
Start taking out possible variables. Eliminate the eboost from the equation and hook a vacuum line from the turbo the wastegate and leave the other port open. That way you know you are only running off the wg spring. If one of the vacuum lines is not hooked up, has a tear or is hooked up backwards, it will never open the wg pretty much max out the turbo, probably blowing your motor in the process.
Making 8psi at 2000rpm doesn't sound right at all. As stated above, I hope you don't have a really small exhousing (should run .96 a/r or larger on a T-4 single front mount).
Old Jan 18, 2006 | 09:12 AM
nossty1's Avatar
Yes its the .96. I dont have a boost controller yet.
Old Jan 18, 2006 | 11:46 AM
bboyferal's Avatar
I thought you had the Eboost?
Old Jan 18, 2006 | 12:42 PM
nossty1's Avatar
Not yet bbforel. I just want to get the car out of the shop but things keep coming up.
Old Jan 18, 2006 | 01:15 PM
Tell them to pull the damn gate off and check to see if it is opening using some vacuum line and an air compressor. You could set the outlet pressure of the compressor at 8 to 10 psi and visually see the gate open. If the gate doesn't open, it busted.
Old Jan 18, 2006 | 05:54 PM
nossty1's Avatar
Well I put in a 3 psi spring and it made 5psi so I guess it is working. We still cant figure out the studder though.
Old Jan 18, 2006 | 07:25 PM
  #32
KissMySSo1's Avatar
You won't have any cyl pressure problems.
Old Jan 18, 2006 | 11:04 PM
  #33
nossty1's Avatar
Are you sure 8psi at 2500rpms seems high. I would think it you wouldnt want boost to come on so early just like you wouldnt want nitrous to come on before 3krpms. Then again I am new to FI and have no idea what I am talking about.
Old Jan 19, 2006 | 04:47 PM
  #34
Got Me SOM's Avatar
if its building that much boost at 2500 then by 5 grand it will probably be close to 15 psi.
I think you have the wrong spring in there personally. for now just run the 5 lb spring.
Old Jan 19, 2006 | 05:46 PM
  #35
nossty1's Avatar
We have the 3psi spring in now and it is still going to 5 or 6
Old Jan 19, 2006 | 07:11 PM
  #36
RedHardSupra's Avatar
boost creep is traditionally linked to the wastegate being too small. but if 'turboslut' says it's enough, then i'd trust him, dude knows his stuff. i'd definitely say it's something hardware related, either not opening at all or not big enough of an opening. i'm very curious to what it is. start exhchanging parts, maybe something's just broken.
Old Jan 26, 2006 | 01:46 PM
  #37
RW99's Avatar
What's the update on this install, NOSSTY?
Very interested to know how the eboost2 is working for you...
Old Jan 26, 2006 | 05:49 PM
  #38
nossty1's Avatar
Sorry man but still no luck. I havent gotten the e boost 2 yet. I need to figure out the problem first.
Old Jan 26, 2006 | 06:13 PM
  #39
bboyferal's Avatar
Aw, man... I thought you'd had it figured out by now.
Wastegate, Turbo, something's gotta be f8cked up!
The God of Turbo Delay... Hey Frost, that really stuck with me.
Don't worry, I have had some delays of my own with the turbo cooking a bit too much oil... but it's getting done with some nozzles and a scavenger pump.
Old Jan 26, 2006 | 06:27 PM
  #40
Frost's Avatar
Well it's not everyday that we can lay a name onto a heretofore unnamed (but obviously real) entity...
His power is clearly drawn from estimated completetion times...
