max psi to run...
Old Feb 4, 2006 | 10:50 AM
bluecamaroz28's Avatar
Originally Posted by 2002 Trans Am
Has anyone done an 88 with an STS? I don't know if anyone has done a 76 either, all I usually see are 67s and 70s
Opps..I forgot it's an sts. That might be another story.
Old Feb 4, 2006 | 11:31 AM
Zombie's Avatar
I'm t76, was even on the stock motor, my friend has a t76 on his stock motor, another guy I know with a 408 has a t76 on his and yet another guy I know has a t76 on his 408. Thats 4 in las vegas. I have another friend with a 67 on his right now, but he'll probably end up going 76 as well. Almost forgot my friend matt, he has a T70 on his. These are all rearmounted kits, some STS, some custom.
I saw mention of a 408 truck with a t88 on it on STS's website, they had a dyno of it too i believe.
it works prett good, if you are auto with a 3000 stall, it's the perfect turbo, ZERO lag, you will see 1lb before the peddle hits the floor, then boost comes up very fast.
Old Feb 4, 2006 | 04:43 PM
2002 Trans Am's Avatar
Cool to hear that
I've got a 3800 stall , i'm thinking GT42-74/76 up front though
Old Feb 4, 2006 | 10:57 PM
Zombie's Avatar
Cool to hear that
That's a lot of stall on a turbo setup. It might run better with less stall.
Old Feb 5, 2006 | 10:54 AM
Yeah i've thought about that, but there is no going back now....Its a really nice converter on the street (Yank SS3800) so i'll see what happens....Worst case whenever I build my tranny up i'll have it restalled
Old Feb 5, 2006 | 12:09 PM
Zombie's Avatar
A midwest 3000 converter goes to 5200 rpms under boost, my vigilante 3000 does the same. I have to see how it drives on the new motor and more boost, but I might need to restall mine lower.
Old Feb 5, 2006 | 05:15 PM
vigs normally run 400-600 higher than advertised.....When the day comes that I have to rebuild the tranny, i'll have to see how much I like the SS3800.....but it certainly will be interesting
Old Feb 6, 2006 | 01:15 PM
boostedtransam's Avatar
Originally Posted by coop5885
thats what im thinking too
well I'm only planning on running 10-12psi at most. I think I should be ok if I stay at this boost level. I know that if I run 16 psi I will need a 76. For now I will be sticking with 10-12 psi. I also wonder what kind of power I will put down..550-600 I hope???
Old Feb 17, 2006 | 10:39 PM
nick y's Avatar
PTK C5 VERT 03
18psi on 93 no meth!!!!!
