760/722 Magna Charger?
Old Jan 31, 2006 | 05:01 PM
BlownChevy's Avatar
blownerator
Default 760/722 Magna Charger?
Yeah that's right! 760 HP and 722 TQ As tested by Duttweiler Performance this afternoon.
Here is the set up:
LS2 402
10.8:1
110 octane
MP122H Beta
Dart 225 out of the box
Crane 236/246 @ 50 114
SCAT Rotating Assembly
UMI 90MM TB
Speed Density W/ Big Stuff
The Video Right Click Save As
Old Jan 31, 2006 | 05:17 PM
ddnspider's Avatar
nobody wanted to listen to me that 1 could make over 600rwhp...and this one did WAY more.....very sick setup!congrats!!thats badass!
Old Jan 31, 2006 | 05:32 PM
Jake the SSnake's Avatar
Awesome!!!!!!!! I think I might have to look in to one of those for my s10
Old Jan 31, 2006 | 06:16 PM
quicksilverado's Avatar
The #s there are crank hp, which would be over 600rwhp. Keep in mind this is with a 122 and not the 112. Still pretty good #s.
Old Jan 31, 2006 | 06:31 PM
wildta's Avatar
What would the engine make without the 110 octane ?
Also what do you think the engine would make without magna ?
Do you have any pictures of the set up .
Nice numbers by the way !!!
Old Jan 31, 2006 | 06:37 PM
XLR8NSS's Avatar
Adkoonerstrator
Over on the truck site he mentioned(going off of memory) that the engine made 560hp naturally aspirated. I don't know if that was with the same oct or whatever else but, it sounded like the only difference was no blower/blower.
Old Jan 31, 2006 | 11:00 PM
BlownChevy's Avatar
blownerator
THat is correct. N/A some octane made 559.8.
Old Jan 31, 2006 | 11:22 PM
moregrip's Avatar
what a rush!
I can live with a nice 200hp gain
Old Jan 31, 2006 | 11:41 PM
NumberOneSled's Avatar
Why so much compression?
Old Feb 1, 2006 | 12:10 AM
Dbluegoat's Avatar
when is this 122 supposed to be available? Will it work on ls1's?
PappyDan's Avatar
Tribe Shaman
Blown let me see the specs on that cam crane, i'm going to build another 6.0.
Old Feb 1, 2006 | 01:09 AM
moregrip's Avatar
what a rush!
the answer is in here:
Actually the MP122H (Beta) is close to the same as the blower you mention. This is an Eaton rotating group with a Magnuson designed rotor housing, this housing is still in Beta testing for efficiency and power output. I am not sure when the public will see production.
As for the "110 Octane"......This motor was set up for some testing with an unrelated performance part, Duttweiler decided to test the MP122H (Beta) on the engine while waiting for some other parts to show up. This was tested in these conditions because that is what was there. I suspect that on pump gas this motor would be a solid 700 hp set up no questions asked. You all should know that this new supercharger is not even close to being finished in the design and testing and is already making preliminary numbers that will SHATTER the competition in the same settings. Sooner or later you will have the reliability of the Magnuson/Eaton supercharger with the power output of what was once considered the BIG DOGS. Sorry boys, better get back to the drawing board, Magnuson is coming after you. Let me reiterate, this will be an exciting year for Magnuson Products Inc. and Eaton.
Old Feb 1, 2006 | 01:23 AM
NOSjohn's Avatar
Restricted User
Kenny is da' man !
Old Feb 1, 2006 | 12:28 PM
BlownChevy's Avatar
blownerator
Originally Posted by NOSjohn
Kenny is da' man !
Yes he is!
Old Feb 4, 2006 | 04:35 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Those are promising results. Hopefully the 122 will fit right onto the 112 intake manifold, making this an easy upgrade for Magna owners down the road...
Tony
Old Feb 5, 2006 | 01:56 PM
chuntington101's Avatar
its not a straight swap. the bolt holes are diffrent.
Chris.
