10.2 compression and boost?
Old Feb 4, 2006 | 01:02 PM
slowredz's Avatar
Default 10.2 compression and boost?
Is this just a dumb idea or would it be ok I am looking to make around 700-800rwhp. It is a forged shortblock. The car makes about 450 rwhp on motor unlocked with a PT4000
Old Feb 4, 2006 | 01:27 PM
Project GatTagO's Avatar
Rally cars run high compression and high boost. Anything is possible with high octane fuel, meth/water injecton, and excellent tuning.
Andrew
Old Feb 4, 2006 | 01:37 PM
chriswtx's Avatar
You should be able to run 8-10psi and be safe. Add alky injection to be really safe...
Old Feb 4, 2006 | 02:06 PM
slowredz's Avatar
Would 10lbs get my goals I figured it would take at least 12-15 I just dont want to have to fill a bottle up everytime I go out which is like 2-3 times a week What size turbo and intercooler would be best for my setup?
Old Feb 4, 2006 | 02:11 PM
chriswtx's Avatar
10 psi should get you close to 650rwhp. 13psi would get you to the 700rwhp mark and probably still be safe...I'm running 10psi on my stock block/stock heads and seeing 617rwhp and 572rwtq...
Old Feb 4, 2006 | 02:17 PM
Drewstein's Avatar
you'll need 10-12lbs to make 700+. On 91 I made 641rwhp on a stock head/bottom end at 9psi. A forged block will better handle the pressure of 10-12lbs of course, and make sure there's no detonation. If tuned properly, you'll be good to go on pump gas.
Old Feb 5, 2006 | 01:58 PM
chuntington101's Avatar
so how about knocking the comp. ratio down a bit with a set of heads? can the stock block (with heads) take 15psi? or is it cheaper to go with low comp pistons?
Chris.
Old Feb 5, 2006 | 02:01 PM
JMBLOWNWS6's Avatar
I would like to line them up if you dont mind. My car is coming soon.
Old Feb 5, 2006 | 03:32 PM
chriswtx's Avatar
Cool...A local boosted car...
I agree about swaping heads to so bigger chambered heads like the LQ9 that have 72cc combustion chambers. That will lower your compression by almost 1 point then you can boost to 15psi no problem
