Need some more advice on turbo build.
I am also aware that i am going to have to upgrade the fuel system, so like 60# injectors, fuel pump and more than likely an inline boost a pump as well as fuel lines.
I guess thats all i have to say so go ahead and critisize im all ears thanks guys/gals
Budget at least $15,000 for a forged short block and a quality turbo kit along with a decent fuel system and upgraded driveline.
Good luck,
Mark
heres what i had
Crankshaft(Callies)- 1600
Rods (Callies Compstars) 600
Diamond forged pistons- 650
Total seal rings- 200
Oil Pump 180
Cam 232/240@.050 .595/.608 lift 115 lope seperation 400
lifters 200
Fuel pump (Wallpro) 160
Fuel injectors 500
Radiator 300
Thermostat 60
Heads(possibly reuse mine) 2000
STS Turbo 4200
Total 10,650
That was my original setup which was like a 383, i just remembered i need an intake also unless the ls6 will work.
so you want a high revving motor cause it sounds cool?
Can I suggest this website for you? www.hondatech.com
Your fuel pump will need to be a 255lph MIN, but most likley you'll need 2 and lines.
Forget reving to 8K. You'll make a stupid amount of power by 6500 anyways.
Also forget these "haters" talking about hondatech. At least you sacked up and asked the questions. That's the only way to learn. When you make crazy power, they'll look more foolish.
As far as hp id like to see 600-650 maybe more.
BOSS APPROVED!
