FI head decisions
Old Feb 13, 2006 | 11:29 AM
  #41
ddnspider's Avatar
if u dont mind sharing what do you 6.0's flow now?nick
Old Feb 13, 2006 | 11:36 AM
  #42
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
They are:
Diamond Racing ported 6.0 heads
2.02/1.57 Manley SD valves (.100 longer than stock)
Comp 977 springs, around 1.8 or 1.85 installed height
~299/219 @ 550-600
~69cc chambers now
Old Feb 13, 2006 | 11:41 AM
  #43
ddnspider's Avatar
makes me feel good about my heads that just got finished from HPE as they flow close.....ill have a 9 sec motor like you....just wont be able to hook for crap.....i just know im gonna go out the first time and run like a 12.4 at 135!
if you dont mind can u pm me the whole flow numbers???
Old Feb 13, 2006 | 11:47 AM
  #44
stevieturbo's Avatar
It's all part of the mix, but generally going to a higher flowing intake makes sense if the heads also flow really well. I'm going from a LS6 intake/tb setup to an Edelbrock single plane and a NW 90mm tb.
I think the turbo will have a lot more effect on airflow than an intake ever will though.
I'd still love to see a single plane intake vs LS6 intake swap on a reasonably small cubic inch ( ie 346-383 )blower powered LS1 to see what effect it has.
Surely someone has done this by now ??
Old Feb 13, 2006 | 11:50 AM
  #45
ddnspider's Avatar
check the new issue of Gm High Tech.They have a stock block camaro SS that swapped from the LS6 setup to a single plain and elbow and went from like 760 up to 830rwhp.Its a D1 blower setup with twin intercoolers
Old Feb 13, 2006 | 11:57 AM
  #46
Being several thousand miles away, I dont have easy access to that :-(
But that is nice to hear..... Single plain+elbow just looks so cool.
Old Feb 13, 2006 | 12:01 PM
  #47
LS1Tech Co-Founder
I think they changed other stuff too, 90rwhp gain from the intake does not make sense.
And Stevie, heat is created when you start hitting restrictions. I am thinking that heads that flow 340/240 (just some numbers) vs 299/219... The former will have less heat, and flow better.
Old Feb 13, 2006 | 12:13 PM
  #48
I was referring to the intake swap John, not the heads.
Any heat increase caused by a restriction would be very very small comapred to the dead created in compressing the air in the first place.
I think that a blower car could suffer more low rpm loss with massive heads, than a turbo car might, as the fixed drive blower doesnt have the same ability to keep pumping air as turbos.
I would think that small port, but good flowing heads are the better option for most blowers. Not sure what effect intakes would have.
Hopefully a single plane wouldnt lose anything down low, but allow the blower to work more efficiently with the heads up top.
The turbo will keep pumping until it reaches the desired boost level, almost regardless of head/intake flow.
CF blowers just cant do that, so sticking with milder heads may be a better option.
Ive no fact to back this up, just thinking out loud.... But its why I chose the Edelbrock heads I did, rather than larger and perhaps ultimately better flowing heads.
Old Feb 13, 2006 | 12:44 PM
  #49
Got Me SOM's Avatar
That's why I'm gonna go with a set of AFR's for my blower setup. Might go with ESP's too don't know
Old Feb 13, 2006 | 01:56 PM
  #50
LS1Tech Co-Founder
Funny, my research told me that if I swapped on some better flow heads with the blower setup I'd make another 50rwhp easily. Air is being pumped in, the less restriction the better. That's why I ran 1.875 into 2.000 step headers with 3.5 collectors.
Old Feb 13, 2006 | 02:18 PM
  #51
ddnspider's Avatar
ill look when i get home in the article but im almost positive that they only did intake stuff to get that hp boost.
Old Feb 13, 2006 | 02:24 PM
  #52
LS1Tech Co-Founder
I was told by folks like Pecos at LME not to put on a fancier intake if my heads didn't flow that much...
Old Feb 13, 2006 | 02:48 PM
  #53
But 50rwhp at the expense of what at the other end of the scale ?
Keeping port runners small in order to make power and torque at the lower rpm's seems to be an important thing. Perhaps more so for a manual car than an auto, which may never really see or actually make use of full throttle below 4-4500rpm ??
Ultimately airflow is king at the upper rpm's for making power, but its always a compromise, especially for a road car.
Old Feb 13, 2006 | 02:55 PM
  #54
LS1Tech Co-Founder
Power and torque down low might have concerned me if my car was 4000 lbs or I was towing a boat. My converter was about a 4500 stall so nothing below that mattered to me.
Old Feb 13, 2006 | 02:58 PM
  #55
Got Me SOM's Avatar
you still gonna run that big ol stall? is it a lockup or non lockup
Old Feb 13, 2006 | 03:00 PM
  #56
LS1Tech Co-Founder
1) Dunno, we'll see what the combo needs.
2) T400 non-lockup, lockup would just be a pain at the new power level.
Old Mar 23, 2006 | 04:59 PM
  #57
LANCE ATKINSON's Avatar
Theyve tested that the LS2 intake sucked compared to an LS6 intake so why would it all of a sudden be better for a boosted application.
Ive been out of pocket for a while! Anyway Pete is telling me that the ls2 intake is better for a positive displacement app than the ls6 and is not as costly as the fast intake and it will out perform both of those on a blower app. Says he has tested this setup. Im putting mine back together this month and Im gonna test his theory! All I have to test is the ls6 and the ls2 though. He says the intake runners make more power on the ls2. It maybe cuz of the bigger throttle body or something I think he ran a 90mm. Has anyone else tested these intakes on blower cars and compared the two?
Old Mar 23, 2006 | 05:58 PM
  #58
MTBDOC's Avatar
Interesting about the LS2 intake. I'm blowing my turbo through it, but that's simply what came on the goat! Eagerly awaiting your experiment!
Old Mar 23, 2006 | 09:08 PM
  #59
LS1Tech Co-Founder
But then you need LS2-specific injectors and fuel rails right?
Maybe I'll flow my new heads.... whenever they get here.
Old Mar 24, 2006 | 07:32 AM
  #60
ddnspider's Avatar
im pretty sure you dont need specific injectors.There was a guy at our shop with a 425 ls1 that had an ls2 intake,and he bent the stock rail so itd fit(dont ask me why ) and stock ls1 injectors and it worked fine..i believe he did have some clearancing issues with the TB though
