Boosted Darton Sleeved 427
Old Feb 2, 2006 | 09:08 AM
BlkHwk's Avatar
Default Boosted Darton Sleeved 427
I was contemplating going with this combo for my Firehawk. Sorry, I have been out of the loop for awhile (spent a lot of time away from home working) but I know there was a lot of info and talk on the darton sleeving process in this forum but when I do a search I cannot find it.
I contacted one of the sponsors of this forum (via email) and they did not recommend and would not build me a boosted darton block, said it was unreliable. I have read about 1200 hp boosted C5R blocks and I would think the darton block would be superior mostly because of the superior liner and increased wall thickness.
I did read recently of a member of this forum that was going to do a 427 and his block had a crack and leaked coolant but did not go into details as far as what caused the crack.
My goals were 725 streetable RWHP (on pump gas) but this is just the number I estimated might be achievable with the 427 and an ATI Procharger. (Maybe this goal was unrealistic but a goal non the less)
Please fill me in on what I missed concerning problems with the Darton block and boost.
(Probably going with an iron block would be best but I would prefer to stay alum.)
Old Feb 2, 2006 | 09:18 AM
ddnspider's Avatar
might want to look at the warhawk block....6 bolts per head as opposed to 4 so itll hold boost better.Bryan Wilkinson did like 850rwhp on pump so u might want to pm him about his setup or search for him.
Old Feb 2, 2006 | 09:20 AM
smokinHawk's Avatar
the manufacture has told me that they would work well, but others have suggested you might have a sealin g problem, honestly i dont know of anyone boosted with a darton sleeved block.
there are a couple of options in keeping an aluminum block you have the ls2 block with a 4" bore so you could do a 403, and also GM is coming out with the l92 witha 4.06 bore so a 412 can be acheived.
those should easily fit your goals and budjet.
Old Feb 2, 2006 | 10:45 AM
mdhmi's Avatar
I've seen several darton sleeved 427's fail with or without boost. Boosting them is not a reliable platform, at least from what I've seen.
If you want big cubes and boost I'd look at the Warhawk, C5R, and LS2 platforms.
Good luck,
Mark
Old Feb 2, 2006 | 11:25 AM
VINCE's Avatar
Shorty Director
Cool
Good luck,
Mark
Darton Wet Sleeve fail? Link me to a post.
Old Feb 2, 2006 | 12:06 PM
BlkHwk's Avatar
Type 427 in search and look for "Critique this 402 Setup"
All he says is block was cracked and leaked coolant.
Old Feb 2, 2006 | 12:41 PM
mdhmi's Avatar
I don't need to post any links. I personally know more than one person who has had problems with Darton 427's.
Mark
Old Feb 2, 2006 | 01:10 PM
93formto98T/A's Avatar
If your goal is just 725streetable hp then that could easily be achieved with a smaller displacement (less costly) longblock setup. A stock cranked iron or alum 6.0L would fill the bill just fine. Save the $$$ for the misc. and unpredictable stuff.
Old Feb 2, 2006 | 02:30 PM
BUYAMERICAN's Avatar
It has been done sucessfully a number of times.
It does have to be put together correctly and with the correct parts.
This is where many builders miss.
I have seen 1,200 rwhp full drag raced 427 Darton at 22 psi.
Irregardless, there have been a number of C5R failures too with only 200-250 shots. All in the build, with the correct parts, imo.
Old Feb 2, 2006 | 02:37 PM
Got Me SOM's Avatar
725 on pump gas can be done with an alum 402 or iron 370 or 408.
personally i'd go with the alum 402 to keep weight off the nose of the car.
Old Feb 2, 2006 | 02:42 PM
2001WS6Vert's Avatar
The new block in the 2007 trucks is going to be a 4.060" bore aluminum which would give you a 415 with a 4" stroke.
Old Feb 2, 2006 | 03:22 PM
BlkHwk's Avatar
I didn't mention hp# when I sent the email to the sponsor but that is what he suggested, and I may go this route.
It just seems to me that if the Darton system works it has a lot of potential for not only displacement, more power potential due to the liners being stronger than stock, but also room for future freshening when needed. Which if I remember correctly, bore size is very limited on the newer LS blocks even the iron blocks.
I talked to a fellow member on the phone today and he said he had probs. with 3 blocks from a builder and claims most of it was due to improper installation of the sleeve's. He had Steve @ race eng. developement do his recent block but decided to go with a different combo.
Old Feb 2, 2006 | 04:04 PM
Got Me SOM's Avatar
I hear what you're saying but even still there are too many stories of dropped sleeves. Why even risk that chance?
Nobody on this forum runs sleeved blocks. Plenty of high hp car/ low 8 cars with iron blocks that have run more than one season hard and they haven't had problems.
Old Feb 2, 2006 | 04:05 PM
BlkHwk's Avatar
Just found a bunch of info.
Gonna be readin a while.
Old Feb 2, 2006 | 04:10 PM
LASTLS1's Avatar
6 Second Club Moderator
Mark
The sleeves aren't the problem. It's who installs them!! Only use Race Engine Development!!!!!!!!!
Old Feb 2, 2006 | 04:21 PM
I do. An LS6 4.080" dry sleeve. I did have a problem with leakage. I had a process called vacuum impregnation done on the block and it has been doing fine since.
Old Feb 2, 2006 | 05:13 PM
Got Me SOM's Avatar
nobody except you I mean
Old Feb 2, 2006 | 06:38 PM
Invisible Sun had a Darton with a big thumper turbo being built. Haven't heard anything in quite awhile though.
Old Feb 2, 2006 | 07:30 PM
paspar2's Avatar
Mark
I needed a laugh... Thanks...
BlkHwk's Avatar
Here is a link to the info I have been searching for off and on for @ least a couple weeks.
I am sure some of you have read it but there will be some that haven't.
https://ls1tech.com/forums/showthrea...3&page=1&pp=20
Hopefully it works.
My eye's are fuzzy from reading it all.
