Vortech SC on LS1
Anyhow, if your car is spending the majority of it's life on the street, low intake temp is what you want. This is the purpose of the aftercooler. Of course a good fuel system is needed too....but the kit covers this, provided your car's not heavily modded.
Anyhow....what's cheaper; The $500-1K saved on the intercooler....or NOT buying an engine rebuild? Also, there are many sponsors offering smoking great deals on the Vortech aftercooled kit now. I got some kick-*** quotes. To respect their wishes, I will not post them on-line. But call around. Deals are available.
As for me....I got an offer I can't refuse on an STS kit. (Hoping to have this puppy installed in the next 2-weeks
)So, this is my route. The Vortech aftercooled kit was my other choice. I'm lucky that my kit works: because I'm outside the USA there is no warranty!!! Of course they write it only in the documents you receive with the kit...
I agree that a cooler will lower the temperature also when not under boost but the vortech setup should have an additional fan. Once you are in stuck in traffic the system has no chances to cool the charge air.
That's why I wrote I would prefer a blow-through setup: the recirculation through the bypass valve heats up the air too much. With a blowh through system the air you don't need is just discharged and the new air will cool down blower + piping.
Got Me SOM You wrote about your IAT at WOT: where is your IAT sensor installed?
If you're not making 500rwhp with boost, then the setup needs to be changed or not purchased in the first place.
Hark-God has spoken..
tici its in the stock location
I mean why not do a H/C setup for less and make 500rwhp? Lets help each other save some money. Or maybe cam and spray? There are several options that are more sane than spending for a blower and getting crap power. If you're going for boost, set the goal at 500...
Oh and didnt notice all the h/c setups are making 500 to the tire now..
Got any times for supposed stock head/stock bottom end 641 rear wheel car?
Why are you so mad at the world? Jealous or something? Kind of juvenile if you ask me. Since when is it a bad thing to watch out for other members and their pocket books?
If we lined them up, you would get worked. Bottom line. But I didn't come on and say I was faster, I said you better make xxx numbers or you're wasting your $$. Take your mullett and negativity to LS1.com.
I know several cam only cars putting down 450rwhp and a few H/C cars at the 500rwhp mark. They all have headers and such as well. Maybe we can actually make power out here...
how bout commenting in a thread that pertains to the subject . You are the one that made that stupid response..I wasn't aware ls1tech was looking for someone to save us from spending too much.
Run your car not your mouth Drewstein.. Trap speed is more of an indicator of a cars true power.
See ya later dyno racer, dyno #'s don't mean jackshit.
The police here considers Nitro a drug because it makes you dizzy when you brathe it. So if they catch you with a bottle in the trunk they bust you butt big time! That's not a joke
So I had the choice between a bored+stroked engine or a SC...
I went with the 6 PSI kit because if I **** up the engine I'm in troubles: spare parts cost here 2-3 times more than over there so I wanted a "safe" setup.
Still a bad choice? It's a 98 LS1 with stock internals, stock exaust and stock intake. The Vortech kit is rated 398 HP and 403 torque for non ram-air cars: it's the first time I see a better result as what vendors advertise, is it really that bad?
I bet that with the cooler it's not going that low
We saw +30 RWHP adding the water-alcohol injection. Only because of the cooling. Same timing (17*), same AFR.
[QUOTE]
Yes it does both aftercooled or not. Drewstein- I have herd and seen many of these same claims and I am not saying that it can't be done it just doesn't happen very often down here maybe our dynos read less? Especially in stock bottom end cars etc... I have personally seen a HC do 440rwhp through a 12(4:10's) and a 6 spd. But this is not an everyday occurance and now a S/C car the numbers are more consitent I have offered up help to a few people and they have all netted excellent numbers. What you are proposing is that everyone will do what you or a very select few have done and that is not reasonable and is misleading to people that are less mechanicly inclined. I am happy with my setup and if this person want to know my honest opinion. It is a great kit that has a lot of potential. Would I purchase the aftercooler? Personally I would. Good luck with your decision brother!
Jeff
Drewstein- Also you are talking peak power, but lets look at the power under the curve for equal powered FI car and a NA car with simular numbers. Peak is fine for a drag car, but more power under the whole RPM range will always be a lot nicer (faster) on the street and will be competitive at the track also. Good luck to you guys with what ever you decide let me know if you need help on your Vortech setups I have a little experience with it particularly.
