Which is Better IC or Meth
Old Feb 3, 2006 | 12:28 AM
tmister's Avatar
Default Which is Better IC or Meth
Which is better on a STS car if I had to choose one or the other and not both and why?Intercooler or Methanol?
Old Feb 3, 2006 | 12:38 AM
ChaseSS's Avatar
intercooler, because methanol would be something you would do in addition to an STS with a intercooler and still wanting more... intercooler would be much more practical at least....someone else correct me if i am wrong
Old Feb 3, 2006 | 12:41 AM
92CamaroReallySlow's Avatar
Well im no Forced Induction expert by any means, but I would guess that almost everyone would say Intercooler. Mainly for the fact of consistancy, and not having to worry about your intercooler "not working" and ruining your motor. Both would be Ideal as long as your not relying on the Meth to keep you within the limit of the motor blowin up in your face. Besides that which ones actually work better as in reducing intake temps, I dont know, but Im sure someone else will chime in.
Old Feb 3, 2006 | 03:08 AM
chuntington101's Avatar
i would go intercooler, then if you want/need more you can put the meth on top! also an intercooler will never "run out" just as yu nail the throtle!
you might also want to look into water injection! does very little to cool the intake, but stop dept pretty well. it was quoted once as "like running race gas all the time"!
thanks CHris.
Old Feb 3, 2006 | 03:56 AM
DeltaT's Avatar
If you had an intercooler that worked, the right size injectors and no detonation, why would you want meth on top of it?
Jim
Old Feb 3, 2006 | 07:03 AM
MTBDOC's Avatar
With methanol you can run more timing => [usually] more power. A methanol/water mix is a cost-effective addition to many boosted cars. I just don't get the 'running out' issue I keep reading about...then again, I put a 1.8 gal tank in the trunk!!!
Old Feb 3, 2006 | 07:14 AM
2001WS6Vert's Avatar
Intercooler first, then meth if your still wanting more (Like most do).
Old Feb 3, 2006 | 07:19 AM
ss97dml's Avatar
they say running meth on 93 octane is like using 120 octane
Old Feb 3, 2006 | 07:48 AM
NA$TY-TA's Avatar
True but you can do the same thing with a well setup IC.
Its cost affective till it stops working.. ie pump stops, nozzle clogged and then your $6K motor goes south..... Just ask Mightey Mouse....
He WAS a big fan of Meth and Pump 93 and always said yes it was done that way..... until his kit stopped working and cost him a complete motor....
You do the the math..... is that cost effective???
Do the IC of your choice and run meth on top of it if needed.
Kyle
