P1SC dynoed last night
Old Feb 5, 2006 | 07:41 PM
Spdmn75's Avatar
Default P1SC dynoed last night
Hey guys I had my latest combo dynoed last night with the following combo:
ATI P1SC Procharger
SDCE 8 RIB set to 14 psi @6600 RPMs
Front mount OBX intercooler
Stock LS1 block bored to 3.905
New LS1 stock crank
Lunati LAE1 rods
ARP main studs
ARP head bolts
Diamond forged dished pistons
02 LS6 cam and springs
hardened pushrods
Stock heads w/GM head gaskets
LS6 intake
Ported throttle body
F.A.S.T. fuel rails
SVO 42 pound injectors
255lph in tank fuel pump
Hooker Long tube 1-3/4” headers with off road Y-pipe
Hooker 3”catback
NGK TR6 sparkplugs
MSD 8.8 wires
I made 606 rwhp and 524rwtq through a Moser 12 bolt with 3:73s
does this sound about right?
Old Feb 5, 2006 | 08:15 PM
frcefed98's Avatar
Damn good numbers to me, but i'm nobody. P1SC? Damn thats real good Might want to watch those 42lb injectors tho...
Old Feb 5, 2006 | 08:25 PM
NOS USER's Avatar
Nice #`s wooow!
Spdmn75's Avatar
Yeah they said thats about it for the 42lbers
Old Feb 5, 2006 | 08:30 PM
TrakDay's Avatar
Nice numbers...
Man... I only got 533 out of my 42# injectors and I was at 109% Duty Cycle, swapped to 60lbers while still on the dyno and went back to tuning.
Be careful with the 42s!
Old Feb 5, 2006 | 08:34 PM
_JB_'s Avatar
P1SC? I thought they only went to 7lbs?
Old Feb 5, 2006 | 08:35 PM
Spdmn75's Avatar
What could I pull with decent 1.6 60ft? on ET streets? anyone's guess?
Old Feb 5, 2006 | 09:27 PM
Blackbird's Avatar
change those injectors right away!
or what your going to do is pop that nice new motor on your ET streets.
Old Feb 6, 2006 | 01:13 AM
ChaseSS's Avatar
i thought the P1SC maxed out at like 11 psi
Old Feb 6, 2006 | 05:11 AM
EPP's Avatar
EPP
Centrifical superchargers put out X amount of airflow. A 346 ci engine isn't going to require as much airflow as a 382 ci to make boost. Othyer variables would be better flowing heads, cams, etc. The use of a stock crank keeping the 346 ci, plus the use of a LS6 cam, and stock heads, would attibute to this P-1SC putting out good boost. I am surprised that it made 14 psi, the SDCE assembly is more than likely responsible for it.
As everyone has mentioned, please jump up to 60lb injectors before something bad happens to your engine. Your 42lb'ers have to be seriously maxxed out. Bob
Old Feb 6, 2006 | 05:13 AM
Slowhawk's Avatar
LS1Tech Sponsor
Nice #'s.
He's probly getting 14lbs because he is ussing stock heads. Boost is measured by backpressure.Throw on some ET or AFR heads and pressure will drop,but hp will probly go up.
Old Feb 6, 2006 | 05:14 AM
EPP's Avatar
EPP
Smile
I'd say high 10's as a guess. Bob
Old Feb 6, 2006 | 06:38 AM
Spdmn75's Avatar
Thanks for the info guys.
Old Feb 6, 2006 | 07:35 AM
gomer's Avatar
I was real impressed with the power the car made Saturday! That was the most power I had ever seen out of 42's or a P1SC. The A/F was rock solid in the 11.8 area and crept up to about 12.5:1 there at the very end of the pulls. Some 60's would be a good bit safer.
Old Feb 6, 2006 | 10:30 AM
Spdmn75's Avatar
How much work would the tune be from 42 to 60s?
Old Feb 6, 2006 | 10:52 AM
gomer's Avatar
Not a big deal at all, change the IFR table and dial the PE table in again. Let me know when you are ready to do it.
Old Feb 6, 2006 | 05:28 PM
Got Me SOM's Avatar
12.5:1 on the dyno will easily lean out to 13:1 or leaner on the street.
car probably runs good though right? a4 or m6?
impressive numbers, my goal is to over 600 to the tire too. Need mo booooooooost!
Old Feb 6, 2006 | 06:47 PM
Spdmn75's Avatar
I guess some 60s are in my future!
Old Feb 6, 2006 | 07:39 PM
Drewstein's Avatar
Nice build. Tell us what you think those 3.73s are like on the street.
Old Feb 6, 2006 | 09:41 PM
Ed Blown Vert's Avatar
Nice numbers, what blower pulley are you running?
