variable geometry turbo
Old Feb 7, 2006 | 02:30 PM
jonus079's Avatar
Default variable geometry turbo
i search on this site and didnt find a single hit. i was looking on ebay for a turbo for my datsun with a 5.3l lm7 sbc gen III engine. i came across this:
http://cgi.ebay.com/ebaymotors/GARRE...spagenameZWDVW
i did some research on variable geometry turbos but did really find any running on a gas engine. is there a reason for this? the VGT seems like a good idea that would work well. i was seriously considering purchasing one of these turbos.
aslo does this turbo hook up like a regular turbo....meaning does it have a wastegate like a normal turbo. what would i have to connect to make the VG feature work?
Old Feb 7, 2006 | 03:23 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Varaiable vane is alot more complex then what is needed for our size engines. Also that turbo hp rating is wrong, and the compressor map they are linking it to is not the correct one. If you match the turbo correctly to your engine, then lag is not an issue.
Old Feb 7, 2006 | 04:45 PM
jonus079's Avatar
damnit....its such a pritty turbo though.....
Old Feb 7, 2006 | 04:49 PM
jonus079's Avatar
btw i found this in my search
http://www.autoblog.com/2005/11/27/n...bine-geometry/
Old Feb 8, 2006 | 07:02 AM
chuntington101's Avatar
speak to baldturbofreak on www.corvetteforum.com
he has done a lot of reserch on them and even put one on his scooby!
thanks Chris.
PS, they are a good itea though and porcshe is using them on the new 911 turbo!
Old Feb 8, 2006 | 09:55 AM
LS1TECH Sponsor
Originally Posted by jonus079
We have a proto version of the KKK VGT series units. Same as the 911 units. They are nice, but the newer units now require computer control units. They aren't standard pressure operated like the older units.
Old Feb 9, 2006 | 12:58 PM
sb427f-car's Avatar
SSU'S Vice Mod
thanks Chris.
Crap...you shouldn't have told me that when I'm ready to rebuild mine eventually...
Old Feb 9, 2006 | 06:04 PM
dws6's Avatar
Banks Performance uses on of those for there diesel kits.
It was on Trucks awhile ago.
Old Feb 10, 2006 | 07:03 AM
yeah they are comonaly used on diesel engines. there was a thing about EGTs of petrol engines hotter and casuing the oil to thin reducing responce and even causing the turbo to spool slower! diesels dont run as hot EGT so they get away with it.
but i think alsot of these early problems have been solved and with newer electronics i dont think this will be a problem!
Chris.
Old Feb 19, 2007 | 09:10 AM
A-man930's Avatar
I would think that the import crowd would be jumping all over the variable geometry thing, they're the ones with the prevalent lag issues...
Old Feb 19, 2007 | 08:56 PM
bigturboz28's Avatar
Default VNT Turbo
I will be replacing my GT42 with a VNT GT42 over the next couple months (need to redue hotside piping to fit T6 flange). I am also installing LQ9 heads and patriot dual springs (I had valve float issues), and want to install a MS system. I have already rebuilt the vane control to fully open ~10psi (theory says I should not need a wastegate). Once i have a little more progress (actually start the hotside build) I will take pictures and post results. I got the turbo from a "friend" at Garrett (in case you are wondering).
I spoke with him about the install, he put one on a GN over a year ago (~30,000mi) without problems (gas temp thing may be a myth). His car will not build boost at idle just sitting there, but WILL build boost (~5psi) without any engine load by simply opening the throttle body in park. (His vanes fully opened at ~20psi). I do not know about everyone else's car, but mine will not build boost now without engine load, I am hoping the VNT will work as well for me as it did for him.
I will start a thread once significant progress gets done.
Old Feb 20, 2007 | 01:41 AM
what a cool project! please keep us informed on how it goes!
thanks Chris.
Old Feb 20, 2007 | 10:22 AM
jonus079's Avatar
id def like to see that. make sure to post some pictures..
Old Feb 20, 2007 | 10:31 AM
flash12t's Avatar
porsche already uses them . .
Old Feb 20, 2007 | 10:38 AM
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by flash12t
This was already mentioned above by Jose. They require though an ECM brain to control, since all the new ones now are not oil controlled.
Old Feb 20, 2007 | 12:23 PM
A-man930's Avatar
How hard could it really be to program something like that into an ECM? I have no experience myself, but it doesn't seem like it would be any more complicated than retarding timing for nitrous/boost or controlling a fuel curve.
...WILL build boost (~5psi) without any engine load by simply opening the throttle body in park.
Now thats interesting... I thought that real boost only comes around when the exhaust gasses are hot enough (a result of the engine being loaded) to really move the turbine... I don't really see where VG would affect that...
Old Feb 20, 2007 | 12:33 PM
kbracing96's Avatar
You are creating engine load by increasing back pressure when you close off the vanes.
Old Feb 20, 2007 | 01:11 PM
A-man930's Avatar
Ah Got it
Old Feb 20, 2007 | 06:46 PM
Default ECM feedback
You do not need ECM control, the reason they are going to ECM control is so that they can meet the new emissions requirements. For all out power (you know so bird fall out of the sky and trees die as you by), a boost referenced vane controller is just fine.
Old Feb 20, 2007 | 08:51 PM
TTAWD's Avatar
http://www.everytime.cummins.com/eve...a/EGRVGTBB.wmv
