almost there!
Old Feb 10, 2006 | 06:55 PM
TOMSBLKSS's Avatar
Default almost there!
im trying to talk my wife into letting me get a STS turbo system... and its working!!! if i nail this valentines day ill be golden. i was wondering what else (if anything) i would need to buy to complete the instalation? im guessing new injectors.... just the stuff i would need to drive it that the kit doesnt include. thanks for the help.
Old Feb 10, 2006 | 07:08 PM
trtturbo's Avatar
Upgrade to the 67 turbo, injectors, pump, stall if auto, good tune, fmic and your good.
Old Feb 10, 2006 | 07:25 PM
TOMSBLKSS's Avatar
its a 6 speed, and what is fmic. thanks
Old Feb 10, 2006 | 07:32 PM
98turbls1's Avatar
Front Mount Intercooler...It's definitely worth it...It'll keep the detonation monster away....Just added insurance...You may also look into a meth kit if you're going to be uping the boost on the stock block...Any little thing can help man...I'm hoping she'll say yes..hahaha
Old Feb 10, 2006 | 07:34 PM
00turboT/A's Avatar
He means get the Front Mount Intercooler with the kit. Bob at exotic performance had one on a camaor SS they did for a guy. He is a sponser check it out----------------------------------------->
Old Feb 11, 2006 | 10:36 AM
trtturbo's Avatar
oh yea, valve springs too. At least 918's.
This will do for the fmic.
Old Feb 12, 2006 | 04:23 AM
Schantin's Avatar
I have $0.02 to put in, as I have an M6 and my STS kit's sitting in the front porch right now .......
What I got (which after boatloads of research seemed best for what I "needed" that wasn't included with the kit):
1. 42lb/hr injectors
2. In-tank high volume fuel pump (such as a Walboro, or in my case the Racetronix 255gph one with wiring harness already made.)
3. Boost gauge
4. Something to mnitor your engine and let you know it's not about to do something "bad". A lot of peple add fuel pressure gauges. I personally added an AEM wideband O2 gauge. Costs a lot, but cheaper than an engine. If I know the A/F ratio to the gnats a$$....no real reason to need a fuel gauge, unless you're curious what the pressure is.) On the flip side, just because the fuel gauge says you have good pressure...doesn't mean you're not running lean.)
5. Blowoff valve (if it's an M6.)
6. Colder spark plugs (NGK TR6 in my case)
7. Better springs (everyone says go for Comp Cams 918 beehive springs) I already have them since I have an aftermarket cam, but I'll list it here anyhow.
8. $$ for a new clutch if you're running the stock one(once again if it's a manual)...as it won't last too long after getting hit by 400+RWHP A torque converter would be a nice "add-on" for an auto car, but doesn't need to be done immediately.
That about covers it. Hope this helps.
Old Feb 12, 2006 | 12:38 PM
TOMSBLKSS's Avatar
wow, thanks for the great response!
