Turbo size for a 402???
Would a 70mm be a good compromise between the two?
WOW... You have your info alllllllll messed up........
A 70mm Turbi.. ie a T70 is NOT bigger then T76=76mm Turbo ro a T88= 88mm Turbo......
So to answer your question...... dont go with either......
You are going to run out of Turbo very very soon running a 402ci motor....
Plus the back pressure...
A T76.... 76mm turbo would work but........ is not ideal and who wants to spend $$ twice for the same thing??? No one...
Go with the T-88 .... and be done with it.
I guess I also got confused when some are saying that a 70mm would probably be ok but a T76 would probably be too small. I am definitely confused for sure. I'm not too sure about running a T88 on the street yet. I think I will try to get a 80mm. Who makes the "best" 80mm? The Best V8 Stories One Small Block at Time
its not like were driving an Import here..... were talking about Four Hundred and two Cubic Inches........
There shouldnt be that much Lag with it..... Look at PurEvils Car....667hp 687tq at only 10psi .......
Rick
See now your saying your afraid of the turbo coming on to soon...... with a T88..... what do you think its going to do with a smaller unit like a 80 or 76mm wheel??? Come on even faster.......
You should have no problems with a T88..........
JZ we need to do a little thread about turbo's for people because like you said..... they think some of these turbo's are to huge for our motor's..
600+rwhp? Hell with a forged 402 and a T-88 more like 700-800+ rwhp!
Apparantly bigger is better but I'm just trying not to be too rediculous and end up with a turbo that supports 1000+hp when I don't really need it. Am I correct in that a T88 is NOT a ball bearing unit? Is it available as such? I know the BB turbos are salty but I only want to do this once and so I'm thinking BB would be the way to go.
88mm with a T6 flange maxes out around 1400 hp at the crank.
A lot of our conversations on here, center our desire to spec a combination that fits our individual needs. The problem is that most turbo companies don't give us the answers we want since (a) it's not good to generalize and (b) half the time they are not sure either since they have not measured backpressure and other issues first hand but are relying on information passed on by costumers.
For 650-700rwhp you need somewhere between a 76mm and a 88mm assuming a T4 flange.
Here again... why.... why go with a ballbearing Turbo...... Twice the money and yes they help with spool time but are the really worth double the price........ my .02.... no..
Now i was talking Pump gas,,, 93 octain...
PurEvils 667rwhp was on pump gas on low boost..... 10 psi.... easier on everything..... with only 10 psi.... Just because you have a turbo that can support 1000hp doesnt mean you have to go ***** out all the time..... and use it all...
Kyle
My recollection is that a 76mm might do 1000hp, and the fastest example is Mike Murillo going high 8's. I don't know what size engine that is, but if it's small cubes it makes sense.
lol i wish i had lag, then i could over 4k without going sideways at 80
