Turbo size for a 402???
Old Feb 14, 2006 | 08:11 PM
  #41
2001-WS6's Avatar
Originally Posted by JZ 97 SS 1500
The turbine wheel (R-trim) though nice flowing is still to small.
Could it be better? Yes.
Can it still support mid to low 9s passes? Yes.
Rick
Old Feb 15, 2006 | 07:52 AM
  #42
SSblack98's Avatar
Originally Posted by PurEvl
my car has never had race gas..yet...the 818hp was 14psi and 14 timing up top on 93 pump
Holy horse crap! Do you have meth or alcy injection? Your #'s are exactly what I am looking for only I would like to stick with an alum block cause I won't be racing/running high boost alot. What heads are you running? I've read 6.0 heads are ok and AFR 225s are best for boost.
Also, I am about to order up a rotating assembly and need to know what cc pistons I should go with for a 8.5-9:1 comp. Lets just say for now that I will run AFRs. What is the formula for calculating comp based on piston -cc, head cc, and knowing headgasket thickness?
Old Feb 15, 2006 | 08:28 AM
  #43
PurEvl's Avatar
i have nothing but pump gas, i dont use meth or alky and probably never will. I will put race gas in it for the first time ever when i go for 4 digits
I got the outlaw iron 408 from combination motorsports..its built for 1400hp(estimate of course). I have -24cc dish pistons with afr 225 heads untouched...im about 8:5:1
This motor with a 218/230 cam with 571 lift on a 116 made 432hp 450tq natural
Old Feb 15, 2006 | 08:39 AM
  #44
RealQuick's Avatar
I am going to be doing a GT42-76 with a T6 for my 383ci LT1....
Old Feb 15, 2006 | 09:37 AM
  #45
PurEvl's Avatar
by the time its done...turbos wont be used anymore...we will all be onto laser beams an ****
Old Feb 15, 2006 | 09:38 AM
  #46
SSblack98's Avatar
That seems like an awfully small cam for a 408. I was thinking of like a 235/230, 600ish lift 114-115 lsa cam for my 402. I thought turbos like a reverse split though I know it depends on your exhaust/intake efficiency. Is that too big a cam for a turbo 402? You must have a great header design to be running that much duration on the exhaust. That thing must idle and drive like stock!
Old Feb 15, 2006 | 09:42 AM
  #47
RealQuick's Avatar
[Chapelle] Cold blooded[/Chapelle]
That hurts Mike... I still want a ride in your beast after that half *** sts ride you gave me.
Old Feb 15, 2006 | 09:47 AM
  #48
SSblack98's Avatar
What is the difference between a "Tan" A/R and "on center" A/R?
Old Feb 15, 2006 | 09:50 AM
  #49
RealQuick's Avatar
He is using 6.0L truck cast manifolds turned toward the front...so no it isnt a GREAT header design. His stuff wont crack though and flows well enough to make the insane power Mike is making.
Old Feb 15, 2006 | 10:32 AM
  #50
NA$TY-TA's Avatar
From alot of the questions you have been asking it sounds like you need to call up an engine builder and discuss your goals and plans with them and then go from there....
Each persons goals are different...
Discuss with them the Block, Pistons, rods, crank, Heads and Compression.
What Your HP and ET goals and plans with the car is.... How tame you want it to be on the street for daily driving and what not.....
The idea behind his cam is its tame.... he could add cats to the car and pass inspections up there....
  #51
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Tangential and Oncenter are just two different types of housings. Nothing more...
Old Feb 15, 2006 | 12:54 PM
  #52
98Z28MASS's Avatar
I was speaking of pump gas. I'm hoping for around 650rwhp on 93 octane. Then maybe 750-800 in race form. I have been trying to really research this but it seems like everyone has a different opinion as to turbo size.
Apparantly bigger is better but I'm just trying not to be too rediculous and end up with a turbo that supports 1000+hp when I don't really need it. Am I correct in that a T88 is NOT a ball bearing unit? Is it available as such? I know the BB turbos are salty but I only want to do this once and so I'm thinking BB would be the way to go.
I was speaking of pump gas too lol! As Purevil's car has shown with the right setup you can make 700-800+ rwhp on 93 octane with not alky or meth injection. Plus as eh said he is still using a fairly tame cam and untouched 225 afrs. If you went with a large CC head, say an ETP 240+, and maybe a slightly bigger cam the same numbers could easily be seen on a 402. I say go T-88 and be done with it. If you go with the T-76 it will spool a little quicker but would lack the top end power the T-88 would have an plus would you really want a turbo that would spool sooner? All that will result in is seeing full boost quicker an annihilating your tires, whereas with the T-88 the slightly longer turbo lag would help with traction, especially on the street.
Old Feb 15, 2006 | 12:55 PM
  #53
PurEvl's Avatar
it idles under stock if you want it to...I put it at stock...it sounds an drives very stock. My clutch is lighter then stock too Im using truck manifolds so not to sure how great they are but there gm's design I have had big cams, they idle like ****, they load up, they stink all the time, they buck with the locker alot. Just not for me
Old Feb 15, 2006 | 07:56 PM
  #54
CHRISPY's Avatar
Pesonally I would forge the 346 (8.8:1) run a 02+ LS6 cam and ETP 215 heads.
Pickup a master power T70 turbo. You'll hit 650 easily on pump and have great spool.
If you want 800RWHP a T76 would work well on 346ci.
If you are 402 I would go with T88 for sure. Spool wont be bad with those big cubes.
Old Feb 16, 2006 | 07:54 AM
  #55
SSblack98's Avatar
Thanks for all the advice guys.
I think I will likely go forged 402, 8.5:1, AFR 225s, T88 up top, fairly mild cam, 99-up PCM and harness. Engine will be in by spring and hopefully boost it this fall/winter. HiFlo should have everything worked out by then.
Old Feb 16, 2006 | 09:45 AM
  #56
98Z28MASS's Avatar
Nice sounds like a sweet combo, def let us know how the build goes and post numbers when you get them!
Old Feb 16, 2006 | 10:00 AM
  #57
RealQuick's Avatar
Just be sure the hiflow kit will work with the T88...layout wise.
Old Feb 16, 2006 | 11:36 AM
  #58
Stupid Boost's Avatar
I think a 402 and 88 have already been done......
Check out this post...
https://ls1tech.com/forums/forced-induction/435980-402-s88-muhahahaaaa.html
Old Feb 16, 2006 | 11:44 AM
  #59
qqwqeqwrqwqtq's Avatar
As far as using a single T4 turbo, we've had the best results with 346-370ci engines and the GT76 R-trim (1.15a/r) innovative unit. More displacement with that turbo has just equalled excessive backpressure, and a shortened RPM range.
We have a PT76GTS here that we've not yet tested.
Also, the only thing we've seen between the GT80R and the GT76R is more lag. In fact, our highest dynoing car with the TTI race hot parts was 370ci and GT76R turbo. (908rwhp 908rwtq).
Old Feb 16, 2006 | 11:47 AM
  #60
SSblack98's Avatar
https://ls1tech.com/forums/showthread.php?t=435980
The S88 is bigger then a T88 right? I mean overall size plus it is T6 flanged I think. It looks like a monster in that pic...
