Speed density tune with turbo?
Im using the MAF T Pro......
so what are my options? i have 98 Z28 soon to recive a 408 with a custom T88 setup. Might even do some twin 61's. i just spent $713 with HP Tuners:
VCM Suite Pro
Item #98 Camaro/Firebird V8. 02 Camaro/Firebird V8. +1Bar Speed Density Enhanced +Enhanced IO 2 Pigtails.
I got an email asking if i wanted to go to the newest version with the credit system and such. Which i did. what am i going to need to tune my car? if it is going to be a big deal i will unload the HP Tuners and get a DFI Gen7 piggyback.
Rick@synergy helped me out with a custom 2 bar SD tune for those of you with 98's.
http://www.devilsownonline.com/alcoh...products_id=18
This is the 2 bar map sensor i'm using, just had to clip off one of the "ears" on it and it went right in.
J
PM FRCefed....... our setups are totaly different and he's closer to what your looking at.
Kyle
Yeah, I hear ya. I've lost count how many days I have into mine. But, I was figuring if a professional tuner had the car, and devoted 2 full days to it, they should be able to get it pretty close. I am nowhere near a pro, which is why I have several days into mine.Fletch, how do you lose drivability? I drive my car everyday and its just as responsive if not better than it ever was with the MAF.
Gas mileage took a small hit, but it isn't bad as some people make you think it is.
And if you're running a MAF and the MAF fails, the car then resorts to SD, you are toast anyway as the SD tables aren't set up to deal with boost, just one bar. So either way you better be tuned into the car at all times.
J
*forgot to put that in my first post
Yep Yep.... it showed up yesterday....
FINALLY...
Wiring is under control..... after that all that is left is mount the seats and there bracing to the cage and the mount the shifter..... then double/triple check everything and she should fire up....... already asked..... video taping is planned.
Kyle
Drivability is better, maybe. I like that I'm not tuning PE at a set boost level. I can set the BC wherever I want and maintain a 11.1:1 ratio.
I used a 12580698 2 BAR MAP Sensor which is a baro sensor from a saturn ION. no splicing / cutting of the factory harness. Just cut off two ears and plug and play. Some pics of the sensor are HERE
But here's a question for you, why tune the VE table in the boost regions when the BE table is going to take over anyway?
Good luck with whatever route you take man.
So what would a BS3 offer most people that the factory PCM cant do ? I would think that in reality, the factory PCM is a much more advanced unit that virtually any aftermarket ecu.
Every aftermarket ecu Ive ever tuned has been speed density. Its quite normal in the UK. Very rarely would anyone want to retain their MAF, unless they insisted re-flashing the factory ecu, which has its limitations.
SD has few limitations.
What in your opinion would a BS3 have to offer, over and above what the factory computer can do running in SD mode, especially the likes of EFILive, which can be mapped live.
obviously systems that cant be mapped live, are a major hindrance.
Obviously another big feature is that it uses a wide-band o2 and can correct for o2 and even has learning capabilities. It can control up to 3 stages of boost (all with their own timing curves and activated by rpm, mph, time, etc) or control a PWM buick factory-type setup to control the boost as well. It can drive any injector without an impedance converter box, and tunes can be loaded on the fly with the car running if you wanted to switch to a pump-gas tune and turn down the boost while you're at the gas station.
It's got a built-in 2-step I believe (don't quote me I'm not even close to knowing how everything works yet) and the system is designed to run the way I'm using it, while a factory pcm is setup to run a MAF sensor and then being changed to run a SD setup.
It seems the money saved on impedance converter boxes, 2/3 bar upgrades, the software itself, mafT, would offset the cost of a bs3 and you'd end up with a superior system. Does the stock pcm stuff work? No doubt, people make huge power on it all the time and have great success. But would they make more power more reliably with the bs3, I am going to go on the limb and say they would. My two pennies though...
I'd rarely even consider using the PCM/ECU to control boost. Just far too mcuh hassle, when you can fit an electronic boost controller to do a better job, much easier and faster. Its also adjustable from inside the car.
High/Low imp is a good feature, Motec ecu's are good that way, as they can drive either type. But unless you are pushing over say 800rwhp, is it really needed ?
As for cost....how much actually is a BS3 ?? Is it plug n play, in that you dont have to make up a loom etc which would cost more ?
As for changing maps on the fly.....well as you need a laptop attached, and a passenger, thats not somehting any normal person is going to do regularly.
How much??
about $2200....
Ill be looking into one sooner or later..... ill have to wait and see how my current setup is going...
