Speed density tune with turbo?
NOTE: I was getting my car tuned at LS1Source and they unplugged my MAF (or forgot to plug it in) one or the other, and blew a head gasket
From my limited understanding of tuning..
As long as you get your PCM set up with a SD 2-3 bar tune..offered by HPT or efilive you are good to go. The MAF will only be able to read so much airflow before its maxed out, on a boosted application thats usually in the mid 4000rpm range. Once the maf is maxed out it can no longer provide fuel for the incoming air. You can cheat your way around it in the PE table.
OR you can do a SD tune and run a 2 or 3 bar map sensor and unplug your maf, disable a few codes and be good to go. Your PCM will add fuel with boost, up to 14psi with a 2 bar map sensor or over 14 psi with a 3 bar map sensor.
Guess LS1source will be replacing your headgasket huh?
J
J
Back to SD: With me only running a max of 10psi of boost right now I will be fine not running the 2-3 bar map sensor? Say I run 7 then want to turn it up to 10, does the computer have to be reprogrammed or is that what you were saying when it would add the appropriate fuel?
Glad they went out of business, too bad they screwed up your car
Yeah you'll be "good" running with the MAF/stock Map sensor and cheating the fuel tables. I did this for a looonnnnggg time with my procharger set up. I ran 15psi with the MAF and added fuel manually after it was maxed out, but you still have to have HPT or EFI live to mess with these tables. Just get yourself a WBO2 and HPT if you don't have it and start learning how to tune
J
This is more important with a turbo which is load based. If the engine is seeing more of a load at a lower rpm than normal (going up a hill or something), the sd tune is the only way to be sure the fuel is correct at a certain rpm. If you trick the pcm to add fuel in the PE table, that is rpm based, and could cause you to run lean in the situation I explained above.
I hope that helps. By the way, I'm in the middle of my 2 bar sd tune, and it's pretty cool stuff!
What exactly is the 2 bar map?
[QUOTE=fletchls1]What exactly is the 2 bar map?
Its what the cobalt ss use because it has a super charger the map sensor plugs into the back of your intake buy the oil pressure sender unit im not to sure how to hook up a two bar map sensor but i have heard its fairly easy and you can buy them from GM granted you have the part number Because stealer ships are stupid
But i havent got a clue on how to SD tune a car some say it take days some say dont do it on a dyno because of load issues got to tune it on the street Will some one please clear this up
out here and i went
an hour later!!! And yes, a sd tune has to be done on the street. If you devoted the time to it, and somewhat know what you're doing, you could probably get it done in 2 full days, 8 hours a day.
man i never knew it would take that much tunning so what will be the differance on a dyno loaded or on the street will u get a better tune on the street or is it play by the reactions of the car
The 2 bar will be right about what the max boost I will see with a 2.75 pulley with the T trim. Here are all the part #'s.GM PN# 12223861 3bar MAP
GM PN# 16040609 2bar MAP
GM PN# 16137039 1bar MAP
GM PN# 15305891 - pigtail harness
From what i Hear HP Tuners will never be doing a 2 or 3 Bar MAP setup for us...... i have a 98.....
Im using the MAF T Pro......
Rick@synergy helped me out with a custom 2 bar SD tune for those of you with 98's.
http://www.devilsownonline.com/alcoh...products_id=18
This is the 2 bar map sensor i'm using, just had to clip off one of the "ears" on it and it went right in.
J
J
Yeah, I hear ya. I've lost count how many days I have into mine. But, I was figuring if a professional tuner had the car, and devoted 2 full days to it, they should be able to get it pretty close. I am nowhere near a pro, which is why I have several days into mine.
