Spark plugs with boost???
Old Feb 20, 2006 | 10:24 AM
Lawnboy's Avatar
Restricted User
Default Spark plugs with boost???
I need to swap out my stock plugs soon, I am installing a D1-sc Procharger on my 01 SS
I see most use the Regular NGK TR6 plugs
Is anyone using the NGK TR6 Iridium plugs ?
are they ary better ,? whats better about them?
Can u use them with boost , thunder racing sais you can
at $7.00 a plug i would not want to wast money if they are not any better than the regular TR6 Plugs.
thank you for your help
Old Feb 20, 2006 | 11:16 AM
cputech's Avatar
I run the TR-6's no problems at all.
Old Feb 20, 2006 | 11:39 AM
bboyferal's Avatar
TR-6's here.
Old Feb 20, 2006 | 01:08 PM
WAHUSKER's Avatar
Iridiums are supposed to have lower misfire rates & last longer. But they also foul more easily. I run the reg TR-6s.
Old Feb 20, 2006 | 02:43 PM
Lawnboy's Avatar
Restricted User
Why would they foul eazy?
do they run to cold?
Old Feb 20, 2006 | 02:47 PM
TIM Z's Avatar
11 sec. Truck Mod
i was told that irridium tipped plugs with forced induction are a NO-NO. something about the tip staying hot and causing detonation
Old Feb 20, 2006 | 02:50 PM
Sixspeed02TA's Avatar
I think one of the contributing factors in the plugs fouling is the richer A/F mix that you normally run in forced induction. At $7 a plug I don't think the Iridiums are that much better.
I would (and do) run Denso Iridiums in my N/A car.
Old Feb 20, 2006 | 02:55 PM
Lawnboy's Avatar
Restricted User
OK i will get my self a set of regular NGK TR6 Plugs
thanks for the help
