Good luck at the track, lil bro!
how much is the rock on tranny gonna set you back, i need to pick me one up before mine craps out.
I had to go turbo
J/K'ing I knew this transition wouldn't be so smooth, I knew the tranny was on borrowed time as well, but its all good at least my drivetrain is now being beefed up because of this.
As for the price of the tranny, it set me back 1950..shipped. I was charged in full at the time of order, so I hope its being put together now.
Push it off a cliff, been there plenty of times, but ehh what can you do, its not like the car did this to itself...if I would have left it stock it would have been fine
Just another step to upgrading the car to suit my needs to go "fast"
sscam68, sorry about your luck at the track too, wasn't such a good day for us out there. Is your car home yet?
J
ps....i hope ur online ALOT the next week or 2 cause the teardown starts tomorrow.Nick
J
I guess I'll start tearing into it on Wednesday. I have an exam Tue. so I have no time for it until then. Its all good though, I just thought I would get a few more passes out of those gears. I'm just glad the diff. didn't puke all over the track. Packed house, 3rd pair up and a greased track. Now THAT would have sucked
12 bolt and bogarts in may
.BTW, I LOVED the stance of your car with the 28's out back. Looked mean as ****.
that post made my day
Thanks for that buddy
I'll try my best to beat those awesome times she laid down today
You can beat those times with both feet chopped off and blind, i'm sure of it.
If you need a hand with the car let me know. I've got a few 10bolt rebuilds under my belt.
J
BTW Jer, I think I got a tan out there, now I look even more mesican
Its early in the year so will have plenty of time, we had some great weather this weekend and it killed me not to go make a couple passes. Running out of fuel again lol, happens every time I change something
ON the second pass an hour later, did a good burnout....launch no shift on the 1-2 or the 2-3 had to slow down to get the car to move to the next gear...once in third it just flew up to 6500rpm and banged the limiter again....13.0@110. Other than that the car ran good, tune looked good...had to lean it out after the first pass because I was getting some rich KR...but the 2nd pass it all looked good. On the drive home if I floored it in 3rd it'd hit the limiter
Got some nice gas out there tho, VP MS-109 octane...7 bucks a gallon....pretty expensive fill up
HO well, Glad I ordered up that Rock ON! transmission last week....saw this coming a mile away.
Once again the march towards tens takes a ******* u turn
J/K
J/K
Guess the dyno didn't lie....but the trapspeeds hint at more like 300rwhp
KP yep just a matter of time before it bit the dust. It was real nice here, usually opening day is cool and windy here but yesterday was perfect.
J
I know once you get that setup working right, you'll be trapping 130+
Im sure the track isnt helping you anyways with elevation and such.
Still thinking about movin out here?
I finally got my car tuned for methanol with a Denny's DS and a 9 inch. Thought I was golden, went to the track and the damn hood came unlatched at the top of 4th gear
All in good time
The last thing on the list and its no priority rush, is also a rear. I've still got the stock 10bolt. But those are cheap and easy to repair and the auto takes it easy on it as well. The 10 bolt lasts me about 2 seasons before something breaks.2000 Tran Zam, I don't know if something is majorly wrong with my car or tune but I was expecting more trapspeed reguardless of what happened. Its not smoking, coolant level is fine and clear. No misses and the a/f was spot on...but yet there was no power. Rick@synergy said it looks like I have a boost leak when he checked out my last log that I sent him....so I have to track that down...if there is one.
It never ends
It never ends
Faulty wastegate(s)? Exhaust leaks?
If you are still thinking that something is wierd as to your not trapping what you think you should, and the dyno doesnt make as much power as you know it should, once you get those other smaller issues taken care of id try running someone on the street/freeway (obviously in a safe environment) and just see how you stack against them.
This way, if you know they trap 125 and your hanging, theres just some bugs you need to work through.
It never ends
I have a 11psi spring for the BOV, I wonder if I should stick that in and see if my power increases.
As for street runs, that was fun when I was a punk kid, but then the punk law caught up with my punk *** and nearly took my car....so now that track season is here, i'll stick to chopping away at it each weekend until the car is running what I want it to run
And I thought I was getting away with boost issues by taking the "belt and pulley" out the equation
Thanks all I keep posting what I find.
J
