H/C vs. F/I
if you go supercharger, expect around mid-upper 400's rwhp with like 9 lbs(which I wouldnt run more then that).
This woudl include all bolt ons and supportive mods.
I would suggest though at least switching to 6.0 heads. It will lower compression and make it safer for you to get in the upper 400's.
if its stock internals, and you dont change out the heads, you prob dont wanna run more then 6 lbs or so, and should net you 400-430 or so rwhp.
As for H/C ....the power gets moved up in the Upper Rpm range were of FI, you can have power in almost any RPm..
As for a H/C car beating a FI with the same HP.. You want to explain that.. HOw N/A cars have advantage to FI
!! i agree with you. check out my post i just added about the NA power/weight ratio vs FI power to weight ratio
Has anyone have thoughts of the STS? What are your views?
For the cam...ith a turbo you want an lsa about 115..
As for the cam, you dont want alot of overlap.. you'll have a little but you dont want so much as all the boost coming in.. goes out the exhaust
