Turbo Paint?
Old Mar 11, 2006 | 03:56 PM
ProtoVette's Avatar
Default Turbo Paint?
Hi,
I have an STS kit ready to install, and I was wondering if I can apply some kind of high temperature paint to the tubo exhaust housings to keep them from surface rusting. Maybe some kind of exhaust manifold paint that you would find in an Eastwood catalog. I don't want to go through the trouble of Jet-Hot coating, as all I'm looking for is something to keep the surface rust away.
Has anyone doen anything like this?
Thanks,
Chris
Old Mar 11, 2006 | 04:04 PM
JustAnIlluzion's Avatar
find a local coater and get it ceramic coated
Old Mar 11, 2006 | 04:52 PM
KraZy's Avatar
I painted my stuff w/ POR20, it smoked real bad the first hr I had it own there. If you can afford better I'd recommend a professional coating.
Old Mar 11, 2006 | 05:58 PM
ProtoVette's Avatar
Do you think it really needs ceramic coating with the turbo in the back, and it seeing much less heat than a front mount?
Thanks again,
Chris
Old Mar 11, 2006 | 06:25 PM
Stupid Boost's Avatar
Chris send your housing out to have it coated.I had mine done by forcedinductions.com and so far it has been holding up great.
Old Mar 12, 2006 | 07:45 PM
ProtoVette's Avatar
How much does it cost to have your housings coated?
Thanks.
Old Mar 13, 2006 | 05:53 AM
smokinHawk's Avatar
did it come off easy or did the por20 stick to it?
Old Mar 13, 2006 | 07:21 AM
KraZy's Avatar
Its still on there, been about 200miles. I havent gone over 3k rpms yet though.
Old Mar 13, 2006 | 07:25 AM
Blown SS's Avatar
Skeered ?
Old Mar 13, 2006 | 08:21 AM
KraZy's Avatar
I still have a meth leak to fix.
Old Mar 16, 2006 | 12:55 AM
fenix99's Avatar
Restricted User
Thanks again,
Chris
i dont think he meant the coating for the heat, the coating helps alot with how it will look over time...wont get as much surface rust as it would with no coating..and about the heat i dont think it will affect it much at all back there
