v6 turbo kit
Old Mar 14, 2006 | 11:16 AM
JustAnIlluzion's Avatar
Default v6 turbo kit
brother has a 99 v6 conv, he was wondering if there is any stock manifold that can be flipped like the ls1 guys flip the 6.0 and 5.3 manifolds.
anyone know?
Old Mar 14, 2006 | 03:05 PM
mightybird's Avatar
[QUOTE=JustAnIlluzion]brother has a 99 v6 conv, he was wondering if there is any stock manifold that can be flipped like the ls1 guys flip the 6.0 and 5.3 manifolds.
anyone know?[/Quat.
i would check on the stock manifolds to see if all the bolts will match up and see if there is any mager obstructions would be a good starting step . if they do then your in good shape other wise check the gn and t type forums and start hunting for some turbo 6 manifolds mabe investing in some good rods and pistons .
Old Mar 14, 2006 | 03:08 PM
Tiago's Avatar
that wont work, accessories are in the way, don't think the bolt pattern would even work.
Old Mar 14, 2006 | 07:34 PM
gen 3 bu's Avatar
sounds like it is time for a base sts kit or custom turbo headers.
Old Mar 14, 2006 | 07:40 PM
Typhoon#1600's Avatar
If you are talking about a 4.3L V6, you will either need a set of syclone/typhoon headers with crossover, or get a pre-fabbed set from www.raceprovenmotors.com. If it is a 3.8L, then go check out the turbobuick guys.... You could always have a set custom-fabbed locally, but be prepared to drop some serious coin on it.
Alex
Typhoon #1600
Old Mar 14, 2006 | 09:30 PM
slow's Avatar
A friend of mine fabbed a set for a older 3.8 V6, search for "shane" on firebirdv6.com and you will see some pics.
Ryan
Old Mar 14, 2006 | 09:48 PM
ah
im thinking just to remove the stock ypipe, and send the new pipes forward to feed the turbo right in front of the engine, theres a nice amount of space there.
Old Mar 15, 2006 | 05:28 AM
smokinHawk's Avatar
youve done a couple of v6 kits how did you route them?
Old Mar 15, 2006 | 07:28 AM
Tiago's Avatar
Several different ways, I think Ive done it pretty much everyway possible...
this is the best though:
http://www.force-fed-fabrications.co...rick/pics.html
