turbo is Loosing boost on the top end
My setup is a PTS kit with a Precision T67Q trim turbo w/ .96 exhaust housing and a .70 coldside housing, PTS FMIC, stock engine W/ LS6 valve springs, Exhaust with 3 inch cutout in front of rear axle
It will bleed off around 2 to 3 pounds from 3500 Rpm to 6500 on a steady decline
It did this before the Valve springs and the cutout was installed
what can I look for to fix this problem
I have a E-Boost 2 bost controller, Mitsibushi (sp) by-pass valve, and A turbosmart 38mm wastegate
could someone please help me with this
is the turbo to small,
I have 2 settings on the Boost controller, 1 for 7 PSI and the other is around 8.5
on both settings the waste gate starts to open at 3.5 to 4 pounds
I have the syn. set on 90 on the higher boost setting
can someone please help me
thanks Darren P
Darren, sorry to hear about the problems...
Are you getting any crankcase pressure? Or are you sure that you're losing your boost via the wastegate?
Seems like one of the first things to try would be to take the boost controller out of the picture and run strictly against the ultragate (w/default 7 lb spring) with the "top" port connected only to atmosphere.
If you're still losing boost while on the dyno, are you sure that your clutch isn't slipping?
And I'll throw this in just because it happened to me: my stock bottom end was fine running 400 rwhp N/A. But as we got to final tuning with my PTS setup, it wouldn't hold higher boost levels. There was crankcase pressurization, and a compression test revealed that #7 just wasn't going to hold on for the party. Hello, forged motor. So that's going into my car as we speak. Hopefully back to tuning it next week, I will keep you posted.
Let me know what you find on your setup...
Rich
thanks Darren P
the waste gate has a 7 pound spring in it
it is peaking at around 8.5 PSI and falling off to 5.9 to 5.5 at 6000 RPM
Forget it... Oooops, I just read now that it starts to bleed off boost starting at 3500 rpm. There has to be something wrong maybe with a line? I changed one of my fans and I lost ALOT of boost... Later I saw a had pinch a line with a tie strap by mistake... Look for stupid things like that maybe?
You sure the Turbo isnt choking out?
However, I hadn't read that the power drops off after just 3500 rpm's, Definitely something else... I rushed through reading his post.
right..
Of course, though, that is not what is happening here.
I riconfigured teh boost controller Hook up to the second method told about in the instructions and it made 11 PSI and I could not get it to go lower
the turbo is not to small for sure
it made 14.5 psi like it was nothing
but I am confused now Because Jose said that if I unhooked the boost referance it would only make about 1 pound more than the spring pressure and it has a 7 pound spring
am i missunderstanding this or just stupid
oh well back to Square one
If i am way off here guys let me know, but i always thought a 38MM WG was risky and too small if your gunna run low boost on our big engines
