LT1 twin turbo
is there any manifold that can be fliped to work on a lt1 to run TT even with little moding?
would i need to change my belt set up?
do i need new heads or could i use the cast iron 58cc?
what type of crankshaft or stroker kit could i get to hold 635+ hp that will not cost over ?
i seen a compay that can give me a 397kit good for 750+hp with custom
piston for 1700+ shiping.
i no all abot the N/A world on LT-1 's but not much about the TT. what would a good 350-355ci kit cost to hold nice power?
If you're going to eventually turn up the boost, forge your entire bottom end and lower your compression ratio to around 8.5:1 - 9:1.
Suspension upgrades are a must.
Fuel pump/inj upgrades are a must.
Tune, tune, tune!!!
i'd run a larger pair of turbos, you commonly find a t3/t4 hybrid's on 4 cyclinders
depending on where your redline is gonna be i'd stay with the smaller stroke of a 350 then a 383
i've seen people cut a section out of a stock manifold and weld a flange on and flip them upside down. but welding cast iron can be difficult
bellville whats that a hour south maybe of pontiac?
i don't think i am that far from you
exhaust manifold ?
well its just what i've seen, maybe you can use a vortec manifold i don't know.
as for a manifold to work for our cars, not really, unless you want to do other things, if you are in the market for a hood, check this out.
http://www.turbochargedpower.com/Imp...SS%2094-96.htm
as far as your belt set up, most of the time it is required but some kits, usually custom can keep it and all acc's.
heads, no you don't need new ones, but to reach the hp numbers you are after, you will ether need high boost, or better flowing heads, and better flowing heads is the better way to go, be it ported, or just better casting. another thing is the deck thickness of the after market heads holds boost better. as well as alluminum disperces heat better than cast steal. but 58cc chambers are fine, just pick your pistons with your whole set up planed first.
and to hold 635 hp, is that flywheel or rwhp? for rwhp, go with an after market crank, eagle are fairly inexpencive, and will hold for more than the hp range you are after. I paid just over 600 for mine shipped, and it is the lightened one. definantly get forged pistons and rods, both a must for that power level.
as for a stroker, a lot of people will tell you to stay with a 3.48 stroke for boost, but I can testify to what a 408 ls1 with boost feels like compaired to a 347 ls1 with boost.
as for the price, I have seen forged eagle cranks and rods with srp pistons for around 1500 balanced, and the price just starts climing from there: heads, fuel pump, fuel lines, fuel injectors, fuel pressure regulator, hot side, turbos, wastegates, bov, intercooler and piping, and tuning (aftermarket ecu or tuning). so what ever price you figure you can do it for, double it.
2 - 50mm T3/T4 Garrett turbochargers with Jet-Hot® Sterling® ceramic-coated turbine housings
this is the samt tubos i was thinking of runing or runing the T4 that are better than them. they come with a one year wanity
i have a brand new,garrett t4 i am trying to sell but don't have enough posts to post in the f/s section lol
was gonna turbo my 350 when i put it in but decided to stay n/a cause its a d/d
ever seen a compressor map?
theres soo much to type and it would take all day. in it helps so you can choose the most efficent turbo
