New 1/8 mile best today
Old Mar 19, 2006 | 05:28 PM
kp's Avatar
kp
Default New 1/8 mile best today
Ran a 6.15 right off the trailer so I knew it was a good day. With the new motor and poly mounts I am getting knock retard up the wazoo though. I pretty much shut the sensors off, no way with 104 unleaded and 16 degrees of timing should this thing be getting 4-6 degrees of KR @ 14psi and 9.5:1 compression. Car picked up 3mph in the 1/8 with them turned off so I doubt its detonating..
Anyhow, best pass was 6.08 @ 113.4, DA was 686' which is great around here. Car is a solid 10th quicker in the 1/8 and 1mph over similar weather last year and it was sliding around a little in 2nd gear. Honestly I could have pulled the exhaust (crappy Kooks Y-pipe and hooker intermediate pipe over the axle) or pulled the ATI inlet hat/filter and probably got in the 5's but my trans was leaking and I didnt want to drop trans fluid on the track, cant seem to find where its leaking from so I packed it up for the day. Still made seven passes, two I had to let out of it because I staged a little too crooked
Still on the 3.7 pulley, still on a 01 Z06 cam, stock pushrods, rockers, stock 98 PCM, LS6 intake, unported Dart 225s and a bit over 3300lbs today. All my good 60's were between 1.343 add 1.358 off the footbrake @ 2800 rpm. Next time out may be with some bigger injectors and the 3.4 pulley
Click here to see Video
Old Mar 19, 2006 | 05:36 PM
onfire's Avatar
Coal Mining Director
113 mph in the 1/8 is wicked....I remember running 105 in the 1/4..............
Old Mar 19, 2006 | 05:39 PM
Josh@PremierAutosports's Avatar
Congrats man. When are you going to a 1/4 track again. What all did you change since last year?
Old Mar 19, 2006 | 05:47 PM
kp's Avatar
kp
Since Bowling Green changed their T&T night to Friday thats out for me so honestly I dont know when I will hit a 1/4 mile track. I may hit Jackson south carolina for a weekend maybe.
Honestly I'm pretty bored with the thing so I think I'll put the other seat in and swap my street wheels and tires on it and just cruise it for a while. Its starting to get to be a handfull to drive without someone getting me pointed straight on the line and if I need a crew guy I'll build a fast car
Anyhow, only changes are a new shortblock, dropped the compression from 10:1 to 9.5:1 or so and bolted on a set of Dart 225s as cast. Thats pretty much it.
Old Mar 19, 2006 | 05:48 PM
CHRISPY's Avatar
That is AWESOME!
Chris
Old Mar 19, 2006 | 05:50 PM
SSilverSSurfer's Avatar
werd...i ran a 113 1/4
Old Mar 19, 2006 | 07:15 PM
frcefed98's Avatar
Congrats Kev Always impressive
Old Mar 19, 2006 | 07:28 PM
TS6's Avatar
TS6
Just bad *** man.......
Do you run it un pump gas on the street?
Old Mar 19, 2006 | 07:32 PM
kp's Avatar
kp
Yea, it slows down a couple tenths on my 93 octane street tune, I run like 12 degrees of timing and fatten it up a little. The 104 is just insurance, drum lasts me a whole season at the track and is way cheaper then a new short block
Old Mar 19, 2006 | 07:35 PM
Navy David SS's Avatar
Nice runs.
You really need to get to a 1/4 track to see it's full potential.
David
Old Mar 19, 2006 | 07:42 PM
kp's Avatar
kp
I would dave but nothing really close here except bristol and that track is as slow as it gets. Plus no slicks on t&t nights and they dont prep the track at all.
1/4 mile situation really sucks around here, its 200 miles minimum to any of the decent tracks around under 1000' elevation My only complaint about living here..
Old Mar 19, 2006 | 08:03 PM
White.Lightning's Avatar
Nice runs like always Kev. You're my inspiration/motivation to get off my lazy *** and finish my install (which has begun by the way ) Once everything is installed/tuned, I will post a bunch of pics and video to share.
Good luck
Andy
NA$TY-TA's Avatar
Bad *** Kevin...... sounds like your getting bored with her to much........ change in the future??
Old Mar 19, 2006 | 08:20 PM
kp's Avatar
kp
Na, just reaching the 'fun' car limit, there is several things I could do to knock a couple tenths off but I really like the car as it is. It just gets to the point where you either make it a race car or keep it a fun car, on one hand its cool to go faster but on the other it is such a simple and reliable combo its really tough to change it.
Old Mar 19, 2006 | 10:32 PM
777's Avatar
777
If you ever get too bored you know where to drop off your setup.
Old Mar 20, 2006 | 05:50 AM
EPP's Avatar
EPP
Nice numbers, KP! I'd swap out that blower inlet hat, and go with an aluminum 4" elbow and a larger filter. Bob
Old Mar 20, 2006 | 06:28 AM
Inspector12's Avatar
TT-TECH Veteran
Nice runs KP.
Old Mar 20, 2006 | 08:05 AM
kp's Avatar
kp
I ran it a few times last year without the blower hat Bob, while it makes a difference in peak boost it doesnt really change the ET much. My filter is the size of an office garbage can
It would probably make a bigger difference if I was spinning the blower higher, only spinning it to like 53K..
Old Mar 20, 2006 | 09:01 AM
NA$TY-TA's Avatar
so you planning on putting the 3.4" pulley on??
Old Mar 20, 2006 | 09:09 AM
Big Geek's Avatar
Any idea what could be causing the KR. Could it be picking up false knock maybe from the blower or tranny/converter maybe on the shifts? It looks like you are running a 28x10.5 under the car; were they tough to get under there? The reason I ask about the tires is that I am going to order another set of 10-in Prostars and would really like to swap gears in order to use a set of 28x10.5-15 so as to get a bigger footprint. That is one good looking car you have, I really dig the videos. Thanks in advance and good luck to ya.
Jim C.
