victor intake?
Old Mar 22, 2006 | 06:23 PM
EDawg's Avatar
Default victor intake?
i was thinking of running a victor intake and 90 elbow with my setup in my sig.
need some input!
Old Mar 22, 2006 | 09:14 PM
Slowhawk's Avatar
LS1Tech Sponsor
need some input!
Here you go. Victor on a 4.8 You need injector's,rewire injector's,fuel line adapters and pretty much redo vacuum lines ect.
These are progress pics,will be done Friday.
Old Mar 22, 2006 | 09:41 PM
BLWN1's Avatar
What elbow and TB is that? I can't tell.. looks good. How much you have in your setup, pm me if you don't mind if you do I understand..
Chris
Old Mar 22, 2006 | 09:45 PM
DanaliHD's Avatar
the intake with rails is $399 at summitt, cheaper other places. The elbow is $200 from intakeelbows.com, and the NickWilliams TB is $420ish unless you can find one cheaper thru a group purchase like the one jandj had.
I'm buying this same setup very, very soon. Nasty performance sells a kit that will allow you to use your stock fuel lines on those rails.
Old Mar 22, 2006 | 10:17 PM
Navy David SS's Avatar
Here's mine. Victor Jr (w/their fuel rails), Precision elbow ($170), Acufab 90MM ($300).
Going with twins.
David
Old Mar 22, 2006 | 10:56 PM
BLWN1's Avatar
damn, is a 90 big enough for all that? looks killer, Im sold on the vic jr setup guys... thanks both of you...
Old Mar 23, 2006 | 09:01 AM
lulu's Avatar
Wilson Manifolds also have elbows and throttle bodies but their elbow seems to be more expensive than Precision.
Old Mar 23, 2006 | 11:57 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
http://psj.ls1tech.com/gallery/main....d=10&g2_page=3
That is what I plan to use. I think the cowl will need an inch of notching, and I"m not sure if my VFN WS6 hood will need some notching.
Old Mar 23, 2006 | 12:38 PM
oldschoolmuscle's Avatar
i just called nasty they sell the kit to adapt to your stock fuel line for 140.00
Old Mar 27, 2006 | 10:47 AM
BLWN1's Avatar
Going with twins.
David
IS that a ford TB, if so do you have to rewire anything?
Old Mar 27, 2006 | 11:44 AM
Spdmn75's Avatar
anyone know if you can use aftermarket rails?
Old Mar 27, 2006 | 08:28 PM
Blwn1 - PM answered - sorry but vacation in the W.I. called
90 should be fine with mine. And yes it is a Ford T/B. Not sure on the after market Fuel rails - I'm using the ones that came with the intake.
Not sure that the stock lines would feed enough fuel for my twins.
And like PSJ said you'll have to notch the cowl, and hood - if stock - my hood is not stock.
David
Old Mar 28, 2006 | 02:21 PM
stevieturbo's Avatar
I guess another question is.....
I dont think there have been many gains over a LSx + stock TB, over LSx + say 90mm TB in a FI application ??
What about TB size when using a carb intake ?? Would the stock TB be seen as a restriction ?
Old Mar 28, 2006 | 08:10 PM
pwrtrip75's Avatar
the edelbrock rails are the same as most aftermarket ones except $100 cheaper.
