sequential twin turbo idea
that way under the preset boost all the exhaust gasses go to one turbo, then as you hit say 10psi, the wastegate opens and feeds the other turbo.
youd probably need something like a 60mm gate
the pre turbo air would be less effected by a restriction and could get by with a single 60mm gate i bet.
why not just mount a throttle body in the hotside of one turbo???? then you can force the exhaust gases to go one way into one thtough one turbo! this would be great for street driving!
then when you wanted more boost then you could have the throttle plate WOT activavted! they take a couple of seconds to open but i bet you could get a faster one using a bigger electric motor or even a boost operated on!!
i have seen these valves used on Evos to vent the exhaust gas staright out to help spool and power! will see if i can dig it up!
and i think you should do some testing! hehehehe
thanks Chris.
The only thing I see as a concern is the obstruction to flow by placing the WG(s) in the down pipe... even a single 60mm gate would choke flow a fair amount. I like the idea of using a large electric cutout (sliding) for this, but I don't know how quick they react.
Give it a shot, I suspect it would work as planned. As stated above... it's easy to fab and convert over if it doesn't work.
Innovative thinking Dave.
the downpipe would have to taper to that which would restrict flow, id think youd want the downpipes 3" or bigger.
I say build the damn thing... it will work!
-cam
this does rewquier some enginering and a lot of pipe work! but it could be done!
Chris.
Interesting for sure.
Ricky
Chris.
Ricky
Supras used it, as did twin turbo Subaru Legacy's. Im pretty sure both cars suffer what some Subaru guys call the "Valley of Death", which is the horrible bit in between when you switch turbos.
If mainstream car makers cant get it to work perfectly, and they would spend millions trying, it isnt going to be easy to get a good workable setup without that backing.
But if you have the time money, and skills to try it, it would be great.
