Damage Report!!
Old Mar 26, 2006 | 01:16 PM
chriswtx's Avatar
Curious as to how much boost you were running and what your AFR was...
Old Mar 26, 2006 | 02:50 PM
KAOS's Avatar
10psi 10.9-11.2 afr.
so does anybody have any prices on that stuff
Old Mar 26, 2006 | 04:45 PM
KAOS's Avatar
for the prices im finding to fix that turbo i might as well buy a new one. what would it really hurt to run that one?
Old Mar 26, 2006 | 04:57 PM
ATTI2D's Avatar
If the shaft isnt bent...then the copmressors should be fine...and judging from the pics...the exhaust turbine doesnt look to beat up. If you can get the turbo to AP or Levi, I can take it up to my turbo guy and have him check it out. I will call him in the AM to see what he can do on a new exhaust housing.
Old Mar 26, 2006 | 05:07 PM
KAOS's Avatar
who is your turbo guy? is he any good? i dont think the shaft is bent just bc it still seemed really smooth at the end of the run. pm or post up some kind of price i would be looking at. i can get it to ap or levi on tues or weds. just let me know thanks
Old Mar 26, 2006 | 07:25 PM
ATTI2D's Avatar
The guy I deal with is out of Ind. He is a Buick guy but know about everything you need to know about turbos. PM me for his name.
Old Mar 26, 2006 | 08:56 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Kaos, this is your best right?
well it didnt blow up. made 579rwhp and 596 rwtq on 10psi. dyno jet and 18 degrees max timing. this thing is beast on the street. thanks for all of the help from everybody taking it to the track tommorow. hope the rear holds up
So did you find the limits of the stock pistons, or did you have a fueling issue?
Old Mar 26, 2006 | 08:59 PM
KAOS's Avatar
i assume its the limit to stock internals. i mean af waas 10.9-11.4 on the dyno. i dont have a wideband in the car so who really knows.
Old Mar 26, 2006 | 09:02 PM
LS1Tech Co-Founder
Yeah that sounds like a safe AF.
Old Mar 26, 2006 | 09:05 PM
68ss_00ss_87_95's Avatar
at least it made some good numbers for stock bottom....i would go along with the other guys as well and get it rebuilt....i had my sc rebuilt after sucking water through it cause i didnt want to take the risk of breaking the new motor it was going on ....im no expert on cars but i work on pumps and all sorts of stuff on my sub and we wouldnt keep that after how the impeller looks....thats just my .02 though
Old Mar 26, 2006 | 09:28 PM
ATTI2D's Avatar
The turbine he has pics of are on the exhaust side...there is no way possible that any foriegn material could have entered the compressor side. Ive seen the impellers totally broke off the wheel and not harm the shaft. If the shaft is true...than the compressor housing and the internals on the compressor side should be fine.
Old Mar 26, 2006 | 10:24 PM
  #32
89Formulaws6's Avatar
rebuild your turbo if you decide to go that route and save yoruself the money, i don't see pics of the turbine housing cause everyone was talking about a housing hmmm.
Old Mar 26, 2006 | 10:27 PM
  #33
KAOS's Avatar
its not there. i dont have a pic of it posted. thinking about selling it still not sure yet. i just dont know what to do.
Old Mar 28, 2006 | 12:25 PM
  #34
juiced_z28's Avatar
You've waited this long. Let the F-er sit a couple of months if you have to. Get what you want and get it done right. I would not put anything that was unsure on a brand new motor. I plan on parking mine for a couple of months to go through it if you care to join me
Old Mar 28, 2006 | 12:39 PM
  #35
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Kaos send us the turbo, we will take care of it. We might be able to service your current wheel which will not cost near as much. Balancing should not be a problem as well.
Old Mar 28, 2006 | 02:22 PM
  #36
KAOS's Avatar
do you think the housing is messed up any? i will get it to ya. thanks
Old Mar 28, 2006 | 02:32 PM
  #37
Scalpel's Avatar
Daniel, they'll be able to tell more once they get it sight.
Besides, it's in excellent hands with them. You've picked great people for your turbo setup, W2W and Jose.
Old Mar 28, 2006 | 02:40 PM
  #38
smokinHawk's Avatar
did you log any knock?
18* timing with stock compression(?) is a bunch
Old Mar 28, 2006 | 02:41 PM
  #39
sb427f-car's Avatar
SSU'S Vice Mod
That's what I'd say. I would def. NOT reuse that turbo without at least getting it cleaned and balanced.
Old Mar 28, 2006 | 03:01 PM
  #40
LTLHOMER's Avatar
Stock compression + 10 or more lbs of boost and 18 degrees on pump gas might be the culprit...were you on pump gas at the track too?
