ATI belt is too SMALL...HELP!!!
Old Mar 26, 2006 | 09:38 AM
BenztechHbl's Avatar
Default ATI belt is too SMALL...HELP!!!
I was installing my Procharger again this weekend, and ran into the problem of
not being able to fit the 8 rib belt around the supercharger after installing it.
Does anyone have any ideas on how to get the belt on???
Old Mar 26, 2006 | 10:06 AM
WAHUSKER's Avatar
MIne is the same way. I usually have to take the blower loose, or you can remove the crank pulley. Neither is much fun. Sorry.....
Old Mar 26, 2006 | 10:14 AM
DarkFormula's Avatar
I usually put the belt on, hang on tight to the head unit (with both hands and my weight), and re-attach the unit hex-head bolts (someone else does this). Otherwise, I can't get the belt on with everything else already bolted up.
Six rib, BTW.
Old Mar 26, 2006 | 09:42 PM
BlownBird68's Avatar
Try it with a 12rib belt! Took my 45minutes and two people.. i got the belt around the procharger than got it on as much as i could with flat head screwdriver (very carefully) than bumped the engine over a few short times. Fortunatly the belt went on after 2nd bump.
Old Mar 26, 2006 | 10:34 PM
Mr. Bungle's Avatar
Six rib, BTW.
+1 for the above
Old Mar 27, 2006 | 05:34 AM
Slowhawk's Avatar
LS1Tech Sponsor
We ussually put the belt on the Procharger then spin it onto the crank pulley by spinning the motor with a wrench/socket setup.
Old Mar 27, 2006 | 03:48 PM
Man, some of you have it easy. But I guess that's why I have no belt slip on a six rib setup upwards of 6800 RPMs
Old Mar 27, 2006 | 07:58 PM
I got it on by bumping the engine...Thanks everyone.
