Ati #'s 5 Psi
Old Apr 4, 2006 | 08:24 PM
  #41
BlownBird68's Avatar
My Procharger pulley is 5inch and im pushing 14#'s with F1 on 357ci
Old Apr 4, 2006 | 08:30 PM
  #42
Avengeance's Avatar
Originally Posted by C.W.A
This kit is from ECS and is superior to the kit from procharger (60# inj.,huge front mount intercooler,custom plumming, etc.) that may be why the #'s seem crazy to you.
PM me a fax # and I'll be happy to send the dyno sheet to you!
I have the same thing.. 60#... FMIC.. custom piping. Im hitting about 9psi at 5900 and Im at 561rwhp, also running out of fuel, need an intank. Thats also with a custom blower cam.. albeit not as big as yours and Im also running 6.0L heads.
Ahh well.. Id be interested in knowing more about your tune. There should also be a number stamped on your blower pulley, instead of physically measuring it... and like mentioned your crank pulley comes into play too.
The other thing is N/A numbers go out the window completely when comparing to boosted results. When you break it all down your "starting" point with your blower isnt 425rwhp... its wellllllll below that. Its not like you started with 425 then added a blower, it doesnt work like that.
Anyways.. they are great numbers.. not trying to doubt ya but something isnt right or like someone said the blower gods are with ya.
Old Apr 4, 2006 | 10:03 PM
  #43
C.W.A's Avatar
I'm running stage 2 ls6 heads(10.8-1,10.9-1). I think the 6.0 heads are 9.5-1 that may be the diffrence in our engines and power?
where did you get your dyno? The elev., temp. could play a small part, I'm at less than 1000 feet and the temp on my dyno day was under 80.
I was also tuned on a dynojet!
Old Apr 5, 2006 | 12:51 AM
  #44
Avengeance's Avatar
Your compression must be it then... that and the tune. No wonder youre only running 5psi.
My dyno was on a dynodynamics calibrated to local dynojets... basically a load bearing dyno that reads similar to a dynojet, but IMO is better for tuning.. especially a SD tune. My numbers were corrected so the elevation and air temp didnt make too much of a difference. Although my elevation is about 25ft and the temp was mid-high 50s.
High compression and boost.. now I really wanna know what kind of timing youre running. Im curious!
Old Apr 5, 2006 | 05:46 PM
  #45
C.W.A's Avatar
I don't know what the timing was set at but I call and post it later!
Old Apr 14, 2006 | 09:07 PM
  #46
C.W.A's Avatar
New #'s with KB boosta pump walboro feulpump and retune!
604rwhp 502rwtq
nice numbers! AF looked good all the way to 6700 it stayed flat and fat!
Old Apr 16, 2006 | 01:08 PM
  #47
WS6 #3392's Avatar
Very nice numbers you got there. Did you ever find out how much timing you are running? Again real good numberes. Let us know your numbers in the1/4 if you take it.
Old Apr 16, 2006 | 02:40 PM
  #48
LSs1Power's Avatar
604rwhp 502rwtq
Very nice
Old Apr 16, 2006 | 02:45 PM
  #49
WestSide's Avatar
604rwhp 502rwtq
Old Apr 17, 2006 | 11:48 AM
  #50
Ed Blown Vert's Avatar
Dyno sheet?
Old Apr 17, 2006 | 12:05 PM
  #51
Race-Prep's Avatar
Suspended Sponsor
I would bet you will all find the timing to be very high, in addition to the compression being up a bit higher than most like to use. We had an lt1 car in here and on race gas with 4-5psi (from an old P600B blower no less) on an 11.2:1 engine it made 500RWHP and about the same torque to the wheels through a loose 400 trans!! Compression and boost make HUGE power....if it stays together!!
-Bryan
Old Apr 18, 2006 | 08:28 PM
  #52
C.W.A's Avatar
very true<
If someone has a scanner I could fax it to you.
Old Apr 18, 2006 | 08:36 PM
  #53
LSs1Power's Avatar
very true<
I used to take a digital pic before i got a scanner. Just make sure you take a good one
Old Apr 19, 2006 | 04:39 PM
  #54
Packy's Avatar
Wow! Very impressive numbers!
Old Apr 19, 2006 | 05:26 PM
  #55
ddnspider's Avatar
very true<
send it to me....321-727-0810
Old Apr 19, 2006 | 11:31 PM
  #56
C.W.A's Avatar
DDNSPIDER corrected #'s on the way! AF is hard to see but it starts at 12.1-1 from 2500-4500 then goes to 11.5-1 to 11.2-1 from 5000rpm-6200rpm then 11.8-1 to 11.9-1 from 6200rpm-6700rpm.
Old Apr 20, 2006 | 10:58 AM
  #57
ddnspider's Avatar
Here ya go,Nick
Old Apr 20, 2006 | 01:35 PM
  #58
LSs1Power's Avatar
Very nice flat A/F ratio.
Old Apr 20, 2006 | 01:40 PM
  #59
ESR's Avatar
ESR
LS1TECH Sponsor
Default .....
Any track passes on that car. Make sure to watch your IAT's may need a tad more fuel as IAT's go up so will the AFR. Just a friendly opinion. I perfer to be around 11.2 to 11.5. Very nice power.
I got the procharger tuned today at lingenfelter in dallas with the 5 psi pulley.
I was hoping for 530-540rwhp,but got a gift when it put down 564rwhp and 490rwtq on the first full pass AF 11.9. Then they tuned it a little more and it threw down 582.8rwhp@6200 and 501.8rwtq@4500-6200. They had to shut it off because the feul pressure was falling of past 6000rpm. Now we are going to install a KB boosta pump and retune with more fuel and go for 600rwhp@6400-6500rpm.
Car is badass!
Old Apr 20, 2006 | 01:41 PM
  #60
ddnspider's Avatar
im still having trouble believing that on 5psi
