Progress is made, track update...
Old Apr 2, 2006 | 10:38 PM
frcefed98's Avatar
solo, yep still on the stock 10 bolt. We did see a truck launch its tire and axle today at the track Made me think twice about these C-clip axles
Thanks too I'll get this turbo to make power one of these day
You'd think that 10psi from a turbo would equal 15psi from a s/c'er on the same car/ set up...finding out that isn't the case.
J
Old Apr 2, 2006 | 11:00 PM
solobaric's Avatar
Wow! Can't wait to see it with a 12 bolt or 9 under it and launching it off a trans brake, should be a beast!
Old Apr 2, 2006 | 11:19 PM
SScam68's Avatar
J
whoa, flashback
Old Apr 3, 2006 | 01:16 AM
KAOS's Avatar
you need that tranny bad. you beat me by the way. at least mph. get it together then come to ky and help with mine.
Old Apr 3, 2006 | 02:47 PM
frcefed98's Avatar
Frank, flashback yep, but that truck guy was worse than what happened to you, his axle and tire were almost all the way out, the axle and tire were touching the concrete barrier and keeping his truck up. At least it was easy to get a jack under it and they rolled it off the track
Kaos, No joke I need to go out there to KY and go pick Kp's brains on tuning...then I'll go over and help you out
Old Apr 3, 2006 | 03:15 PM
KAOS's Avatar
bring it to ky and make more powrer and run better times. good luck
