manual boost controller?..opinions?
Old Apr 6, 2006 | 07:48 PM
30th t/a's Avatar
Default manual boost controller?..opinions?
i just bought this hallman manual BC. i have a buddy with one and he loves it and said their a good manual BC. now i have people telling to not to even try it and this and that. should i get rid of it now or try it out? whats your experiences with a manual BC. ill hear by some people they like them, then i hear other say they suck.
thanks for the info.
Old Apr 6, 2006 | 10:43 PM
Jammer's Avatar
the good ones, are ball and spring
NOT A BLEED ... but not always true, the turbo XS works great
Its a bleed valve, but vents to atmosphere, and if you use the line from the intake, its a constant vacume leak
not sure about yours... my bleed one sucked (turbo smart)
My electronic innovative was awesome
Old Apr 6, 2006 | 10:57 PM
2001-WS6's Avatar
Why would anyone want to get out of the car to turn the ****? I reserve my excercise efforts for going to the fridge to get another beer. Electronic boost controllers rule.
Rick
Old Apr 6, 2006 | 11:04 PM
LTLHOMER's Avatar
Nothing wrong with manuals for us low-budget folk...and having it under the hood keeps you from turning it up when you wanna crush that new z06 next to you by 20 car-lengths instead of just 10.
Old Apr 6, 2006 | 11:50 PM
Rusted40's Avatar
I use one for each turbo
have them mounted under the dash
this allows me to adjust each seperately
there is also a on/off valve on the boost source line
once you have the boost where you want it, shut off the valve and back to low boost
I suspect a nitrous solenoid could also be used to activate it remotely
I agree with not using the bleed method
I have had better results introducing boost to the top of the wastegate
Old Apr 7, 2006 | 05:16 AM
30th t/a's Avatar
all i want is max boost and power on 93 octane. why? because im on the street 99.999% of the time and im not going to running race gas 99.999% of the time. i wont mind getting out of the car every once in a while to crank it up when i decide to run race gas.
Old Apr 7, 2006 | 07:53 AM
mcx's Avatar
mcx
i picked up a cheap ball/spring manual boost controller to use on my rear turbo car.I see people recommend connecting one end to the intake manifold.Is this also recommended for a rear mount set up???Seems like a long run of vacuum hose!!LOL.NEED ADVICE.thx,mike.
Old Apr 7, 2006 | 11:53 AM
Rusted40's Avatar
I used 1/4 steel brake line and rubber hose at the joints
seems less likely to collapse
I referenced the boost signal from the intake
turbonetics showed schematics for bleeding boost to the wastegate or
introducing boost to the top of the wastegate diaphram
I used the latter without any problems so far
Old Apr 7, 2006 | 01:23 PM
mcx's Avatar
mcx
..THANKS FOR THE TIP....i'll pick up the longest piece of brake tubing.
Old Apr 7, 2006 | 01:32 PM
89Formulaws6's Avatar
people just don't like manuals because some people don't know how to run lines to install them to the dash so they keep it under the hood haha, and i think the main reason is in fear of boost creep.
imo i'd use one, cause not everyone is a baller and can get a electronic.
brake line for a boost controller line
i don't see the need but to all their own, rubber lines are fine
Old Apr 7, 2006 | 02:13 PM
PurEvl's Avatar
i run a manual to protect me from myself
Old Apr 7, 2006 | 03:30 PM
93formto98T/A's Avatar
GMR tried a manual BC for the twins but it wasn't keeping the boost consistent so they yanked it and put in a blitz DSBC digital BC. No complaints.
Old Apr 7, 2006 | 03:36 PM
y2khawk's Avatar
dual port gate with light spring + $10 air pressure regulator = dead nuts solid boost.
I just think some people over complicate it, or just like widgets with blinking lights
Old Apr 7, 2006 | 03:39 PM
hellbents10's Avatar
LS1Tech Sponsor
