** 76GTS questions
Old Apr 17, 2006 | 02:38 PM
Turbo LS1 SS's Avatar
Default ** 76GTS questions
i SUCK at reading turbo maps, so, a simple answer would be nice
the motor is an iron 365 with AFR 225s. what kinda efficient boost limits can i expect out of a 76gts on a motor with that VE. the extra cubes were kinda last minute and i just want to make sure im gettin the right turbo. and would a .96a/r be an appropriate sized E.H. or should i go differently. this is for a street car that will see ~800 GIVE or take.
preaciate it
Old Apr 17, 2006 | 02:50 PM
forgot to add.... revving to ~6500rpms
Old Apr 17, 2006 | 03:35 PM
MECHAM's Avatar
u got the map for this turbo?
Old Apr 17, 2006 | 06:22 PM
Frost's Avatar
+1
I haven't found one; please post-up if you do.
Old Apr 17, 2006 | 06:37 PM
theres a map for a t76 on this page about half way down:
http://www.forcedinductions.com/help.htm
Old Apr 17, 2006 | 07:11 PM
ddnspider's Avatar
they dont make a map for a t76gts,just the generic t76.unless jose has an update
Old Apr 17, 2006 | 07:39 PM
Frost's Avatar
they dont make a map for a t76gts....
That's what I've been told as well.
Old Apr 17, 2006 | 08:15 PM
DrTurbo's Avatar
LS1TECH Sponsor
Jose said that is a map for a 76mm p-trim unit. But he has a tested map they came up with, but I don't think he shares it with the public, not sure the reason.
Old Apr 17, 2006 | 08:31 PM
ddnspider's Avatar
he told me to just shift it 10lbs and itll be close
