FI troubles
Old Apr 25, 2006 | 06:15 AM
clemsondave's Avatar
Default FI troubles
Something strange has been happening lately to the Z06. Under hard acceleration in 3rd gear, the acceleration tapers off. It does not pull all the way to redline like it used to. At first, I thought it was the clutch slipping. However, it does not do it in 1st or 2nd (m6). I have tried watching the boost gauge, but it's kinda tough when going that fast. I'm going to make more runs with someone watching it.
Any ideas? How can I narrow it down? What does it feel like when the belt slips? Could the clutch only slip in 3rd? Springs? I have babied this things since I have had it; I cannot imagine this clutch slipping. See mods in sig below.
Old Apr 25, 2006 | 06:21 AM
Frost's Avatar
Does the belt that drives the blower itself look like it has been slipping?
Old Apr 25, 2006 | 07:10 AM
I took a quick glance at it yesterday and the belt looks ok and I did not see any belt dust. However, it was a very quick look; plus this has only been happening the last two times out. I will check this afternoon. Steve, when I took you for a ride, it was pulling all the way through. Now it falls off in 3rd. I want to get this fixed before going to the track with ya'll.
Old Apr 25, 2006 | 08:40 AM
Frost's Avatar
I don't remember seeing it/them, but do you have a fuel pressure guage and/or wideband?
Old Apr 25, 2006 | 08:50 AM
No, I think the theory was that running only 7# of boost, it should be safe with the 42s and Kenne Bell boost a pump. But, I am not sure.
If it was running out of fuel, wouldn't it have happened from the start? I have been trying to figure out why it only happens in 3rd. I have not pushed it to 4th (dont need to spend time in jail).
Old Apr 25, 2006 | 09:02 AM
KraZy's Avatar
Valve Float? Are you still using stock springs?
Old Apr 25, 2006 | 09:32 AM
Yep, stock everything except mods below.
CHRISPY's Avatar
Clutch slip will be worse in 3rd and 4th versus 1st and 2nd.
Old Apr 25, 2006 | 10:32 AM
Boostaholic's Avatar
Indeed, my old T56 setup would slip in 3rd-6th but not 1st or 2nd. And it would always slip at the top of the power band
Old Apr 25, 2006 | 06:52 PM
chriswtx's Avatar
On a side note...You should at least get a fuel pressure guage...I started running out of fuel at 550rwhp in my 2004 Vette with a boost a pump and 42lb injectors. Also if you fuel pump ever starts to weaken and fail at least you will see it with a guage...
If you engine if pulling to red line in 3rd and 4th but the car doesn't seem to be accelerating at an equal rate then its probably the clutch slipping...
Old Apr 25, 2006 | 06:59 PM
thanks for all the help guys!
It pulls HARD in 1st and 2nd. Then around 3500 RPM in 3rd, the acceleration goes away. The RPMs do not rev up fast (like I would think they would if it was the clutch).
Is there anyway to test for valve float?
Old Apr 25, 2006 | 07:05 PM
chriswtx's Avatar
No way to test except to pull a valve spring and see if its still at spec with a valve spring pressure tester. It could be fuel pressure problems with the higher load in those gears or it could be the computer pulling timing because of engine knock, it could be blet slip but it doesnt sound like it, could be a boost leak some where ..All just ideas of what it could be...
Old Apr 25, 2006 | 07:11 PM
Thanks Chris. I've got some guys coming over Friday to help. I do not see any dust from belt slipping.
Old Apr 25, 2006 | 07:57 PM
Guys, is it possible this is related to the new 10% Ethanol gas in Virginia? This issue seamed to show itself about the same time all the pumps were switched to Ethanol.
Old Apr 25, 2006 | 08:26 PM
Frost's Avatar
As much as you hate to plant the equipment in that car, a fuel pressure guage and a wideband would sure help me sleep at night if it were mine.
Old Apr 25, 2006 | 09:42 PM
dws6's Avatar
My car does the same thing on occasion. Stock clutch here. I have noticed the car does not make as much boost in 1st or 2nd (about 5 psi in 2nd) as it does in 3rd or 4th (8psi). I think boost is kind of referenced to load on the vehicle. So technically your are making more power in 3rd than 2nd causing the clutch to slip there only.
Thats my theory anyway.
Old Apr 25, 2006 | 09:44 PM
FastKat's Avatar
Sounded like the clutch at first but if it's not racing to the redline as you lose acceleration, I guess the clutch is ruled out.
Old Apr 26, 2006 | 10:08 AM
RW99's Avatar
See if the same thing happens in a lower gear when you're going up a fairly steep hill. If it does, your loss of power is load related and most probably the clutch slipping, IMO.
You'll also see the obvious blip to redline mentioned above.
Old Apr 26, 2006 | 10:25 AM
GrahamHill's Avatar
What does it do in 4th?
edit: Might wanna put a set of valvesprings on it while help is around.
Old Apr 26, 2006 | 11:04 AM
RW, no loss of power going up hill in 1st and 2nd.
Graham, I have not tried it in 4th. Not ready for a ticket going 100+.
I guess no one thinks much of the Ethanol theory?
