View Poll Results: Which do you think is the most dependable
Supercharger
58
28.16%
23.30%
Turbo
59
28.64%
Twin turbo
41
19.90%
Voters: 206. You may not vote on this poll
Most dependable extreme setup?
Old May 2, 2006 | 03:45 PM
orion565's Avatar
Originally Posted by Optimus_Prime
... im not sure what cubes are. ...
cubic inches
Old May 3, 2006 | 07:20 AM
Gold Phoenix's Avatar
I'd like to run low 11's/high 10's. I would do both autocross and drag racing. I would get forged internals, im not sure what cubes are. I would prefer 18+MPG on the highway and it would have to be streetable since its my daily driver...Cost dosent matter, I have time to save.
For these goals, I would say a stock cube, small cam, turbo motor. I say that because you can make your power goal, have a wide powerband for AutoX, and still retain you gas mileage. With the high output like drag racing, the exhaust components need to handle more heat than supercharged or nitrous motors.
Old Jul 18, 2006 | 04:40 PM
Sparetire's Avatar
Originally Posted by RyanJ
True.
Extreme at the track would be like 700+ cid w/ twin big frame 94's or so. Extreme on the street would be like 700+rwhp.
HOWEVER - N/A is the most dependable no matter what the goals are. Sorry. For FI, turbo's (either twin or single) will be faster all else being equal but they will also be more expensive and require more involved tuning in most cases. Supercharges are a bit simpler, but can have belt issues.
I disagree in "extreme" cases. The kinds of things neccesary to get say a 346 Cube motor to make 800WHP are going to shorten its life. In order to make that kind of power NA your looking at very high revs, agressive cams that can roach valve train components etc. Now if you have a big 427 or so, it really ups the ceiling a lot, but even then, consider what it would take to get an NA 427 to hit 900WHP.
If you can get a 572 or something though, then I would probably agree. But I dont think I have personally seen anything over 502 in a modern Vette.
With a FI setup you can run lower revs, milder cams, etc. You might get more heat from inefficiencies in the turbo or super, but intercooling has advanced to an amazing degree. A well thought outsystem would be able to deal with this heat effectively while sparing the bearings, rotational assembly, input shaft, block, valve train, etc high rev abuse. Which IMHO is the #1 killer of all engines.
For say 900WHP, I would say the most reliable route would be a 408 with a single and perhaps a shot.
Old Jul 18, 2006 | 04:43 PM
Boodyrider's Avatar
408. BIG rear mounted STS or STS style turbo, cut out the rear trunk area to mount the big turbo up high, intercooled, and maybe a 100 shot to spool at the track.
Old Jul 18, 2006 | 05:02 PM
longrange4u's Avatar
Turbo.... least amount of moving parts, dosent directly touch the motor, most efficient. IMHO
Old Jul 23, 2006 | 12:53 AM
Boostaholic's Avatar
Originally Posted by NHRAMAN
Turbo / Flux Capacitor is the bestest.....
x2, I would go with the flux capacitor setup
Old Jul 23, 2006 | 03:31 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
How extreme do you want to go? Build a 454 ci LSX motor with a 3.3L twin screw being fed by a 101mm thumper turbo ( with a 200 shot of nitrous to spool, of course). Sorry, but the "extreme" question lends itself to idiotic replies.
Old Jul 23, 2006 | 06:51 PM
Got Me SOM's Avatar
for road racing/autocrossing supercharger all the way, the power is more linear and easier to control.
Old Jul 24, 2006 | 04:46 AM
2MuchRiceMakesMeSick's Avatar
its what you put in your drink to make it cool.
he is talking about cubic inches.
im doing a twin turbo setup if I ever get the kit
Old Jul 24, 2006 | 08:10 PM
mongse's Avatar
I ruin the end of films...
If you go turbo, you'll definitely succeed in the whole "not being good" part of autocross. It may be best for a straightline track car, but that's about it.
If all you're looking for is high 10s/low 11s, just do heads and cam and bottle it. It'll be a lot more dependable (and cheaper) than a turbo or blower setup.
Old Jul 25, 2006 | 07:28 AM
SS2win's Avatar
I dunno about not being good at autocross. I won SM2 my first time out (having never autocrossed before) and beat out the top points guy by a almost a second. I blame the incon kit for getting me to the turns faster.
I'd go with turbo(s). you'll spend more money to get it going but it will be very street friendly with oh **** performance when you need it. having more linear power brings a supercharger in close second but belt tension and crank pinning scare me off.
Old Jul 25, 2006 | 08:56 PM
  #32
Ari G's Avatar
900whp is not so hard on a stoked 350 with Turbo,Do your homework and you will get there
With FI the pressure and heat of high boost kills rings,r.lands ect and blowby will occur,heads and mains will allso see alot of stress
Old Jun 3, 2007 | 11:23 PM
  #33
LSInnovations's Avatar
I'd have to second that
Old Jun 3, 2007 | 11:37 PM
  #34
Your only a year too late
Old Jun 4, 2007 | 08:41 AM
  #35
NoGo's Avatar
Considering this was brought back from the dead.
My D-1 setup is still kicking with some minor adjustments. Had some belt issues when I first brought it out in April this summer, but now everything is okay again.
I expect another good summer of daily driver 700 RWHP fun Putting ~100 miles a day on it.
Old Jun 4, 2007 | 03:34 PM
  #36
CHRISPY's Avatar
Personally I have gone the supercharger route but not the Turbo route.
I would still vote blower with a good bracket/pulley setup like the SDCE for your goals.
ATI D1SC...Even the bigger 4.5 inch dual intercoolers would work fine for you at the power level you are looking at and be dead reliable with the right fuel/tuning especially if you go forged...
Old Jun 19, 2007 | 09:11 PM
  #37
SS2win's Avatar
I've been to chicago twice (1000 miles each way), augusta and orlando a bunch of times, new orleans, etc. almost went to LA but the job fell though... 30,000 of road since my last post. still have oil pressure and power to pass in a second or two... lol
Old Jun 22, 2007 | 07:44 AM
  #38
cablebandit's Avatar
extreme and reliable dont go together...thats why its extreme ; h/c for your goals
Old Jun 22, 2007 | 05:02 PM
  #39
ocdwill's Avatar
Old Jun 22, 2007 | 09:40 PM
  #40
SS2win's Avatar
naah turbos are easy on parts..
