Kenne Bell Kit Sizes
Old May 1, 2006 | 01:09 PM
Phillip Lawrence's Avatar
Default Kenne Bell Kit Sizes
Here are some measurements from the kit. Hope this helps. I am putting the blower on an LS2 (going into a 1969 Camaro). The kit is meant for an LS1, so it took a little tweaking.
The kit is about 9.5" tall from the ground to the top of the blower. The is plenty of room in the back.
Old May 1, 2006 | 02:04 PM
InsomZ's Avatar
awesome how many psi u plan on running? i'm curious what kind of header/tranny setup works for the '69?
Old May 1, 2006 | 04:45 PM
I am using a built T56 out of a late model Camaro and I am using Stainless Works long tube header. I am shooting for 10 psi and we will see how it goes. If will take more safely, I will go to 11 or 12 psi.
Old May 1, 2006 | 05:03 PM
soontobeLS1's Avatar
Kenne Bell came out with a kit for the F-Bod??????
Old May 1, 2006 | 05:14 PM
BLWN1's Avatar
Really, where....
Nice setup
Old May 1, 2006 | 05:59 PM
Z28Camaro01's Avatar
http://www.kennebell.net/supercharge...gmCorvette.htm
Old May 1, 2006 | 06:05 PM
NataSS Inc's Avatar
I cant wait to hear that thing run. Please have a video camera the day it fires up.
Old May 1, 2006 | 06:07 PM
unit213's Avatar
Administrator
2.6L right?
Old May 1, 2006 | 07:15 PM
BLK02TA's Avatar
I dont think it would clear our firewall or cowl part whatever its called.
Old May 2, 2006 | 08:02 AM
Currently Kenne Bell only has a kit for the LS1 Corvette. I am having to make a few changes to make it work on an LS2. Yes, it is 2.6 liter blower with a water to air intercooler.
If would take some serious cutting to fit the kit on an F-body. It may not even be possible. How tall is a Magnason? This is about 9.5" tall. The rear of the blower has a ton of room.
Old May 2, 2006 | 12:40 PM
chuntington101's Avatar
phill what mod have you made to the KB to make it fit the LS2??
i see that Turn Key Engines are now doing a LS2 with ione on!
thanks Chris.
Old May 3, 2006 | 07:47 AM
The new valley cover supplied will not work at all (It's for an LS1). You have to modify the stock one. Counter sink all the bolts, shave of the PVC fitting, fill PVC hole, and shave back the oil pressure sending unit .
I also had a problem on the driver's side coil pack. I modified the stock bracket to work, but it would be a lot easier to move the coils if you have room.
These are both easy things for KB to correct when they offer an LS2 kit.
