View Poll Results: How many cubes for the street with a 76GTS tubular manifold kit?
36x"
47
38.84%
37x"
45
37.19%
38x"
11
9.09%
402"
18
14.88%
Voters: 121. You may not vote on this poll
How many cubes for street 76GTS?
Old 05-15-2006, 08:55 AM
SUPER DAVES Z's Avatar
Originally Posted by Frost
The final setup will be 9.46:1 with lq9s (this is based on the following data and a formula told to me by an old timer, maybe it's wrong? 4" bore, 4" stroke, -14cc dish, .055" MLS compressed size, 72cc chambers).
That's the compression ratio Ross comes up with so your old timer was dead on! http://www.rosspistons.com/calculator.php
As far as the 402 goes, It may not the the most "optimal" set-up to max out a T-4 turbo, but it will still make some sick power on pump gas. I’m also willing to bet it does not have a much back pressure (which is obviously the concern running a larger CI motor with a T-4 turbo) than some of the less efficient single turbo kits running on 346’s.
I’d much rather have a PTS kit on my 402, than an old TTI or QMP kit on my 346. IMO it will be a good set-up and make nasty power on pump gas.
Later,
Dave
Old 05-15-2006, 09:30 AM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Originally Posted by had20z
just curious on a built 408 what turbo would yall suggest?
If you can fit it, then the S-series units will pack the most amount of power for the size.
Jose
Old 05-15-2006, 09:32 AM
LS1TECH Sponsor
Later,
Dave
Agreed, say no to single logs
Old 05-15-2006, 02:45 PM
engineermike's Avatar
HEY! I resemble that remark. . .
Old 05-15-2006, 02:46 PM
LS1TECH Sponsor
lol, yeah....
Old 06-22-2006, 08:39 PM
Frost's Avatar
Now that I'm not being pushed towards a particular setup, I'm going back stock-inch LS1. I am hoping for good numbers maxing this 76GTS out on race fuel.
Old 06-22-2006, 08:52 PM
1bdbrd's Avatar
where did you pick up your 76gts and if you dont mind how much did you pay for it? im in the same boat (sorta) as you. im looking for a great all around turbo that will make around 700rwhp or better on either race gas or pump and alky. i was planning on around 20psi or so for high boost. i was originally planning on a t67 or a t70 but a local supra guy ran the 76gts with GREAT success (10.0's@140) so i want to check into it...
*EDIT* but im also working on a strict budget as well.
Old 06-22-2006, 09:27 PM
I've run 143 with my 76GTS in my full weight LT1 camaro at 18 psi in the La heat. It's been proven over 150 mph and 990 rwhp.
Old 06-22-2006, 09:32 PM
Frost's Avatar
That's good stuff Mike.... once my new setup is in and the kinks are out I hope for similar. 140MPH trap was my goal from the beginning.
Old 08-23-2006, 07:59 AM
longrange4u's Avatar
I voted 370 cause you dont have 34x... but either would work fine. I think for the street a 370 would be great cause it would give you near instant spool.
Old 08-23-2006, 08:01 AM
Frost's Avatar
It's still a little restrictive on the exhaust side for a 37x inch setup.... your upper RPMs would suffer. This poll was from when I was being pushed towards one stroker or another without the option of a stock-inch replacement.
Old 08-23-2006, 11:04 AM
  #32
NA$TY-TA's Avatar
Soooooooooooooooooo and updates Buddy????????
I plan to come up that way when my axles get back....
You still want those rims and tires????
Kyle
Old 08-23-2006, 12:23 PM
  #33
Frost's Avatar
Kyle
Hell yeah I want 'em, I was gonna send you a PM last night (but I passed out instead ) about them...
Mine is so close to the street that I DARE NOT SPEAK OF PROJECTED TIMING Alas, I have been seriously downtrodden and scorned by the Mighty God of Turbo Delay. I see you have appeased him; I'm working on it.
Old 08-23-2006, 02:22 PM
  #34
NA$TY-TA's Avatar
Cool im glad...... Yes the Turbo Gods have smiled on me.... Now if the axles and wheel studs gods would do the same
PM me your # and ill add it to my phone and ill give ya a heads up when we are headed up your way.
Kyle
Old 08-23-2006, 02:57 PM
  #35
Frost's Avatar
Pm sent
Old 08-24-2006, 07:37 PM
  #36
2000 Tran Zam's Avatar
My vote goes for a t88 or 91mm
Old 08-25-2006, 06:32 AM
  #37
Frost's Avatar
See Kyle? DO YOU SEE ??? My mere hinting around here brought me more INCREDIBLE MISFORTUNE. Maybe by next summer....
Old 08-25-2006, 07:17 AM
  #38
NA$TY-TA's Avatar
Sorry man...
Did ya callhim yet???
Kyle
Old 08-25-2006, 11:36 AM
  #39
Frost's Avatar
Nah, REAL busy at work.... too busy for ls1tech even... It seems that he bought it that way, this was nothing deliberate on his part.
Old 08-26-2006, 06:23 AM
  #40
NA$TY-TA's Avatar
So whats the plan??? new bearings???
Quick Reply: How many cubes for street 76GTS?
