6.0L boost
Old May 4, 2006 | 07:02 AM
jason02Z's Avatar
Default 6.0L boost
my cars almost finished and ready for boost..what are u guys running for boost on stock motors with 6.0L heads. im prob going to be running around 10 so whos getting more boost and how long are ur motors lasting..i have all the softwear and able to get a tune
Old May 4, 2006 | 02:06 PM
fast240z's Avatar
Default Didn't last long
I had a customer with a STS 04' silverado SS who turned his boost up to 12 psi. It lasted about a week and then it broke #7 and #8 pistons and rods. It also took out the block, cam and other misc. parts when the broken rod was swinging around. A costly mistake! I am in the process of putting together a new motor for him which should be very sturdy. He doesn't want that to happen again. Stay below 8 and last forever.
Mark
Old May 4, 2006 | 02:14 PM
mkoch1's Avatar
I a running 9.5 no IC, just meth.
mark
Gordy M's Avatar
The stock bottom end will not handle more than 5-6 lbs of boost. Usually #7 goes and when it does, it often takes #8 with it. Many thought it was a lean condition but even those running rich have had it happen. The lower the boost the longer they last.
Forged bottom end is good insurance.
Old May 4, 2006 | 03:06 PM
Zombie's Avatar
I've tuned several stock motors from 8-16psi and none have had an issue as long as they are smart about it, i.e. good gas on high boost, monitor knock, etc. My personal motor was seeing 16psi from the 67 turbo and 15 with the 76. It finally broke after 15k boosted miles due to rod bolt stretch from having a 6700 limiter on stock rod bolts. Started to get a slight rod knock, pistons were fine (except for the ones that I floated the valves on, 918 springs).
Old May 4, 2006 | 03:48 PM
jason02Z's Avatar
k thanks for the info...im gonna start around 8-9lb. with a T70 and maybe run meth
Old May 4, 2006 | 03:50 PM
Zombie's Avatar
Just remember, it's all about the tune and how well you babysit the motor to make sure it stays happy.
Old May 4, 2006 | 05:21 PM
jason02Z's Avatar
yeh i know its all in the tune we have HP tuners..as long as im happy too haha
