Offset twin turbo sizes..????
Old May 10, 2006 | 10:23 AM
Z06PSI's Avatar
Default Offset twin turbo sizes..????
What are the hurdles in this.??? Lets say a 60 for quicker spool for one side and a 70 for the other for some more topend... This is just a thought guys so keep flaming to a minimum.....
Old May 10, 2006 | 10:49 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Backpressure is not equalized on the turbine side. So basically the engine will be fighting 2 different forces.
Old May 10, 2006 | 11:08 AM
TchargedLS1TA's Avatar
Not enough room to run sequential turbo's efficiently in these engine compartments
Old May 10, 2006 | 12:41 PM
Z06PSI's Avatar
Could this be remedied by using different exhaust housings and wheels....????
Old May 10, 2006 | 04:32 PM
eviltwins's Avatar
No, but it could be remedied by using two properly sized turbochargers.
A pair of PT61 P-trim .68 A/R turbos will do over 1000 to the wheels without maxing them out, and will be fully kicking by about 4000 RPM's. What more do you want?
Old May 10, 2006 | 04:38 PM
Boostaholic's Avatar
Indeed - I think I posted in the other thread about this saying that it was not necessary. In my setup I never see "lag" or have to wait for boost to come in. That may be a problem as I crank it up into the 20s but at 10lbs it was never a problem.
Old May 10, 2006 | 04:45 PM
LS1TECH Sponsor
No, the pressure delta will always be different due to the differences in wheel sizes and masses.
Old May 10, 2006 | 04:46 PM
LS1TECH Sponsor
Right or a pair of TE44's will spool VERY fast and still give top end. If not go with a set of Dual BB 60's.
Old May 11, 2006 | 10:18 AM
Z06PSI's Avatar
Thanks guys.. just something going through my head...
