which block
Old May 18, 2006 | 05:00 PM
1evilss's Avatar
Default which block
I am planning on buying the sts kit and runnin around 8-10 psi and I want to know which block to buy and what internals I will need. would flat top pistons be the way to go or dished? Which rods? And Which heads. Keep in mind this will be my weekend car.
thanks
Ronnie
Old May 18, 2006 | 05:08 PM
y2khawk's Avatar
How about a power goal?
you really don't need to do much of anything for <10 PSI on a stocker. Just upgrade your injectors and fuel pump and have at it
Old May 18, 2006 | 05:10 PM
SS1875's Avatar
Check with the sponser's >>>>> They can definatley give you all the info you need and some ideas on things you might not have thought about. Good luck with the build.
Old May 18, 2006 | 11:02 PM
KAOS's Avatar
i hate fn alluminum. over tighten then you have to helocoil the m'fr. whats 80 lbs when you make 600+ rwhp. if i had it to do over it would be iron for me. but who am i my car isnt even running
Old May 19, 2006 | 05:15 AM
EPP's Avatar
EPP
Check out the STS Camaro SS in the project car section of my website for some ideas. Bob
