Got her done...
Old May 20, 2006 | 03:01 PM
Tiago's Avatar
Default Got her done...
Now just need to do the SD tune
From stock other then the rods and pistons, to now this.
AFR225 heads
TR224 Cam , chose the 114
victor jr intake
NW 90mm TB
and a bunch of other small things that went into it while I Was in there.
I'll be able to have a good comparison between a "stock" motor and a h/c/i setup with boost, I'll start the tune at the same boost as previously, 12 psi, where it made 595 rwhp on a mustang dyno before, and see what it will do now. Expecting HUGE area under the curve gains
then the boost will go up
Old May 20, 2006 | 03:04 PM
ls1king000's Avatar
Looking really good. I'm ******* jealous. Beautiful
Old May 20, 2006 | 03:05 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Good job, can't wait for new dyno and track numbers. Those hard lines seem like they would be a major pain, but they look good. Where does the role of sandpaper mount to?
Old May 20, 2006 | 03:28 PM
BlackCamaroSS02's Avatar
your the man Tiago
Old May 20, 2006 | 03:42 PM
SSilverSSurfer's Avatar
damn tiago...that is nice...your numbers are gonna be bad ***...im sure your gonna erik take care of the tune for you..he will work some magik...now i need to find a turbo kit for my car
Old May 20, 2006 | 04:13 PM
NA$TY-TA's Avatar
damn man work is blocking the pic...... ill see it when i get home.....
Old May 20, 2006 | 05:30 PM
onfire's Avatar
Coal Mining Director
Very, very, very nice........
Old May 20, 2006 | 05:44 PM
unit213's Avatar
Administrator
Looks phenominal. Great work!
She's going to make a **** ton of power.
Old May 20, 2006 | 05:53 PM
Hardtop's Avatar
Great job, Congrats.
Bruce
Old May 20, 2006 | 06:03 PM
DanWS6's Avatar
That looks awesome, great job.
Old May 20, 2006 | 06:06 PM
FUroundeye's Avatar
Kickass! I forget, what turbos are you running again?
Old May 20, 2006 | 07:14 PM
sgt0704's Avatar
don't you hate it? my work is blocking too... mother *******.
Old May 20, 2006 | 07:39 PM
SantaCruz163's Avatar
Looks like it'll make a **** load of people. I'm not digging the steel hard lines. Me personally, I would have used braided steel lines; but that's just me.
Old May 21, 2006 | 12:49 AM
Malicious's Avatar
Tiago > hard lines... man if I tried anything like that it'd look like ***...
Old May 21, 2006 | 01:12 AM
Inspector12's Avatar
TT-TECH Veteran
Looks great!
Old May 21, 2006 | 09:03 AM
BLk01SS's Avatar
Very nice!!! you otta try to clean that alternator. the whole engine bay is clean and new, but it sticks out like a sore thumb. Whole setup is kick *** though!!
Old May 21, 2006 | 09:09 AM
Tiago's Avatar
thanks everyone
Old May 21, 2006 | 09:24 AM
Navy David SS's Avatar
Looking good. Couple of questions: turbo size? fuel system? How are you going to tune this beast - stock computer????
Good luck
David
Old May 21, 2006 | 09:36 AM
Tiago's Avatar
Good luck
David
My kit hasn't changed from the last motor setup, Twin 70mm turbos. Fuel system is twin walbro intank pumps, to 3/8" Y block, then -8 line from the y all teh way to the rail and about halfway back, where it joins back to the stock feed line, only have 65lb injectors in it for now but looking for the upgrade. Im also Running stock PCM with 3 bar enhancement with HPtuners. Eboost 2 controls the boost.
Old May 21, 2006 | 09:41 AM
CrawlinWS6's Avatar
Import Patrol
Damn! Nice looking set-up!
