Forward headers done!!!!!!!!!!!!!!!
Old May 22, 2006 | 06:26 PM
lcvette's Avatar
from Corky bells maximum boost, he references that a turbo can be cocked a certain degree for fitment with out negative effect on oil drain or function.. obviously it would be safest to have it parallel, but a slight tilt should not destroy an engine. as for the pick up tube not getting oil...????? how is that relavent to the turbo or did I miss the point there.. just asking.. unless the turbo is pumping oil past a blown seal and not returning it to the pan, it should not effect the oil pump pick up whatsoever. and if this was the case.. you would know something was wrong long before you drained the pan below the pick up level.. you would fog out an antire city block with blue smoke.
Chris
Old May 22, 2006 | 07:17 PM
Turbo V6 Camaro's Avatar
Originally Posted by Camaro_Zach
gravity doesnt work when youre staring at the sky. thats how mr magnus blew up his motor. oil goes to back, pickup tube is exposed, then you got no oil to pump. just sayin that gravity isnt what you think. dry sump would be perfect...ah my next setup...i cant wait to do it all again and do it all right.
the 3800 pick up tube is the back of the pan
Old May 22, 2006 | 07:19 PM
Chris
well if it goes the other way your IC will fill up with oil.... that would SUCK
Old May 23, 2006 | 12:04 AM
lcvette's Avatar
either way, if it goes the intake route.. it will make it through the engine.. cause its gonna be blown out the scroll at HIGH velocity.. gauranteed to get to the plenum and throught he motor making blue smoke.. either way its not a good idea and should be avoided.. I agree with gravity drain being the ideal return system if the turbo is mounted high enough, and if adequate hose routing to the return point can be implemented.
Chris
Old May 23, 2006 | 08:27 AM
RealQuick's Avatar
yes. you are 110% right. so by being sarcastic, you were correct. props. turbos have no "upright" position, their boxes do not say THIS SIDE UP. you can **** the angle that the turbo sits at if its for fitment, or just for clearance, or even ease of getting at the bolts.
way to be an *** to andrew, hes mah boy.
Wasnt trying to be an ***...just trying to point out that "it being custom" has nothing to do with it being cockeyed. Andrew, sorry f I was an ***
Feel better now
Also, adjusting the angle for the drain/feed is ok, but I would avoid tilting side to side to avoid starvng one seal and and flooding the other. That will cause some oil to either get into the turbine housing or compressor housing depending on how he sets up his turbo. The current angle may not be a problem...but it was just a heads up originally.
Old May 23, 2006 | 10:07 AM
Camaro_Zach's Avatar
Feel better now
Also, adjusting the angle for the drain/feed is ok, but I would avoid tilting side to side to avoid starting one seal and and floodig the other. That will cause some oil to either get into the turbine housing or compressor housing depending on how he sets up his turbo. The current angle may not be a problem...but it was just a heads up originally.
im just messin around anyways.
Old May 23, 2006 | 11:37 AM
bc56f100's Avatar
Hell yea cant wait to see this thing out again!!!!!!
Old May 23, 2006 | 01:15 PM
NoMoreLS1's Avatar
Question
How is this going to fit in the car? Are you mocking this system up entirely on an engine stand? What is going to happen when you try to install it in the car with all of the accessories?
Old May 23, 2006 | 01:41 PM
Tiago's Avatar
its called a JIG
Old May 23, 2006 | 04:07 PM
Originally Posted by Tiago
its called a JIG
what he siad
Old May 23, 2006 | 05:11 PM
bradmb's Avatar
theres lots of space when you drive a v6...
anyways, im from panama city/pensacola. seen this car around, saw it one day at the mary esther mall and driving through gulf breeze. you should go to driven2modify.com and come hang out with some of the guys there. i think you know some of them already from what i hear. anyways, car is def. a sleeper. nice setup. but all that work makes me want a v8 even more.
Old May 23, 2006 | 05:30 PM
  #32
thanks and a just s turbo kit is not that hard........ high 12s easy
i want 10.99 so got a got a few extra toys
Old May 23, 2006 | 05:37 PM
  #33
98Ztwentyeight's Avatar
It's custom.
Andrew
exactly when something is a little different its called
custom or a feature
Old May 23, 2006 | 06:08 PM
  #34
NoMoreLS1's Avatar
Thumbs up
its called a JIG
Yeah... no kidding. But he never made any mention if this was going to fit in the car. Anyone can "eyeball" something out of the car on a "jig". I would be making the turbo headers on the car personally.
Old May 23, 2006 | 06:16 PM
  #35
car in FL, headers in houston tx = kinda hard
jigs are used to make everything from headers to head light brackets i dont see the differance here.....
plus theres a 97 car there they can test fit them if need be
Old May 23, 2006 | 06:43 PM
  #36
NoMoreLS1's Avatar
Thumbs up
Ah... so this system was already in a car, huh?
Old May 24, 2006 | 07:32 AM
  #37
Tiago's Avatar
there is a "sister" kit to this one which was in a car, we used that kit to make the jig, so its good to go.
Old May 24, 2006 | 07:43 AM
  #38
quit building crooked kits tiago hahaha
Old May 24, 2006 | 08:17 AM
  #39
CHRISPY's Avatar
Weld a little tube on the bottom of your dipstick and run your oil return to it. No problems on decel or accel
Old May 24, 2006 | 09:32 AM
  #40
NoMoreLS1's Avatar
Thumbs up
Ah... that makes sense.
