Forward headers done!!!!!!!!!!!!!!!
Old May 21, 2006 | 07:21 PM
Turbo V6 Camaro's Avatar
Default Forward headers done!!!!!!!!!!!!!!!
well only wastegate and one flange to weld.....
Old May 21, 2006 | 07:48 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
looking good so when do i go pick them up hehehe J/K
Old May 21, 2006 | 08:22 PM
Boo"SS"t's Avatar
Good job! what size turbo are you gonna run with that?
Old May 21, 2006 | 09:50 PM
tiago made them
turbo is the Master Power T70 /.68 hot side
Old May 21, 2006 | 09:59 PM
Boo"SS"t's Avatar
That should make some serious power.
Old May 21, 2006 | 10:28 PM
SSilverSSurfer's Avatar
Tiago made the headerS?
Old May 21, 2006 | 10:29 PM
yup set up a jig, from the first set he did, and made them from that
Old May 21, 2006 | 10:49 PM
damn he needs to make me some...lol
Old May 22, 2006 | 08:27 AM
RealQuick's Avatar
Any reason why the T4 flange is cocked to one side? Just wondering. Other than that it looks good!
Tiago's Avatar
looking good
Old May 22, 2006 | 10:07 AM
Project GatTagO's Avatar
It's custom.
Andrew
Old May 22, 2006 | 10:12 AM
Tiago's Avatar
it will be corrected before I weld the flange on, right nwo its just sitting there, and the jig got bent over some while we put the Y together.
Old May 22, 2006 | 11:16 AM
RealQuick's Avatar
It's custom.
Andrew
That has nothing to do with anything. So its ok to have it cockeyed because its custom?
RealQuick's Avatar
Thanks for replying. So its not welded, just located for right now. Looks good.
Old May 22, 2006 | 04:32 PM
if that the ony way it fits why not?
but really what tiago said
Old May 22, 2006 | 04:50 PM
Camaro_Zach's Avatar
yes. you are 110% right. so by being sarcastic, you were correct. props. turbos have no "upright" position, their boxes do not say THIS SIDE UP. you can **** the angle that the turbo sits at if its for fitment, or just for clearance, or even ease of getting at the bolts.
way to be an *** to andrew, hes mah boy.
Old May 22, 2006 | 04:52 PM
yeah as long as the oil drains out your safe
Old May 22, 2006 | 04:58 PM
scavange pump. sts and lingenfelter both use this.
Old May 22, 2006 | 04:59 PM
no thanks one more thing to worry about....... i'll stick with gravitty
Old May 22, 2006 | 05:04 PM
gravity doesnt work when youre staring at the sky. thats how mr magnus blew up his motor. oil goes to back, pickup tube is exposed, then you got no oil to pump. just sayin that gravity isnt what you think. dry sump would be perfect...ah my next setup...i cant wait to do it all again and do it all right.
