Trick to Sealing V-Band clamps?
well in addition to an oil leak..i just started my Turbo setup for the first time...i have a few exhaust leaks...two of them being v band clamps.
Aside from making sure theyre flush before tightening, does anyone have any tips to help these seal? Are they somehwhat problematic?
Im getting popping from air being mixed into the exhaust.
Originally Posted by 618HAWK
It is standard practice on aircraft to spray some lube on the flanges and internal portion of the clamp prior to installtion. It also helps to tap on outside of the clamp while tighting to specs..
The tapping on the outside of the clamp when its tight...then retightening..tap more...tighten more...works well.
But most of all...they have to be aligned right. You may think they are aligned good...but if they are leaking chances are they are still off a bit.
Originally Posted by Ping King
thanks everyone...ill try the tapping trick...i have a 4 inch DP going over a stock k member..so hahah yea its a little tight in there.
some have taken high temp rtv sealer between the flanges.
would bad sealing vband clamps cause backfires then?
mine has been backfiring like crazy, but i thought it was something in the tune. im gonna have to check and see if their sealed now.
well my tune is off...the car has 96 lb injectors in it..i set the injector flow rate tables correctly and lowered the minimum pulsewidth....and at cold start i think theres too much fuel being tossed in...that and with the leaking v bands its probably adding air at just the right places....theres def flames shooting out of the v band connections when it back fires.
Im going to cut some of the fuel enrichment at cold start and see if it helps, but these exhaust leaks def need to be fixed.
