MP T70s mounted
Old May 27, 2006 | 07:41 PM
Boostaholic's Avatar
Default MP T70s mounted
Here is a little mach up picture of MP T70s mounted. Car is down at the machine shop now getting the headers fixed up.
Old May 27, 2006 | 07:49 PM
Tiago's Avatar
MP T70s FTW
Old May 27, 2006 | 08:13 PM
braap's Avatar
Originally Posted by Tiago
MP T70s FTW
It's the latest craze...lol!
Looks good, man. I assume the 408 in your sig will be pushing them? Should be nasty
Old May 27, 2006 | 08:20 PM
Yeah the 8:1 408 freshened up with new pistons, rings and bearings will be the engine.
Old May 27, 2006 | 08:28 PM
Josh@KY-Turbo's Avatar
Damn to think I am running one T70 on my 346.
Old May 27, 2006 | 09:02 PM
bboyferal's Avatar
In our defense, we're running only a 346...
Okay, that was weak... +1
Old May 28, 2006 | 01:44 AM
94redz28's Avatar
Where did you get your MP T70's at?
Old May 28, 2006 | 09:22 AM
Navy David SS's Avatar
Looking good guy. What are you going to do for I/C? You already swaped out the stock PCM for a BS3 right? I still believe you'll do a lot better with an air-2-ice intercooler set up. Fan? Rad? I think I have found a great combination. It takes at least 10-15 minutes just to get the car temp up to 140, and than kick in the 3000 cfm Spal fan and it goes down to 110 . If you need any suggestions just ask. Boise is a long ways from any major shop. What's your cam spec's? Who's doing your work?
Good luck. Keep us posted.
David
Old May 28, 2006 | 01:33 PM
David
Its a big griffin A2A, Ron Davis radiator. And we are doing all the work that does not require a welder.
Old May 28, 2006 | 03:26 PM
SSilverSSurfer's Avatar
good luck....it gonna be nasty
Old May 28, 2006 | 04:30 PM
98turbls1's Avatar
I agree...It's going to be a nice little setup when you get it done...
Old May 28, 2006 | 04:38 PM
TwoFast4Lv's Avatar
Very nice!
Old May 28, 2006 | 05:02 PM
stang90gt50's Avatar
Master power turbos are a good deal...
how much did you score the T70's for?
Old May 28, 2006 | 08:58 PM
Project GatTagO's Avatar
Thats a lot of turbo....
Andrew
Old May 28, 2006 | 11:05 PM
stevensLS1's Avatar
very nice man! cant wait to see some numbers!
Old May 29, 2006 | 08:39 AM
MetallicTrans96's Avatar
What are the numbers you plan to make with that setup???
Old May 29, 2006 | 09:25 AM
1FST99Z's Avatar
what are you going to be doing with the ABS. or is this only going to be a strip car. Sweet looking setup.
Old May 29, 2006 | 10:10 AM
Cory1970's Avatar
looks great...just an FYI, took my twin master power t-70 355 lt1 out the other day, saw positive boost pressure at about 3700rpm...and it was climbing fast, but i backed out at about 5psi because its not tuned well yet, but the way it was climbing im sure full boost would hit below 4400rpm...so your 408 should spool them rather quickly
good work, keep us updated!
Old May 29, 2006 | 01:29 PM
I guess most of you are not aware this car was running with twin T70s last year. It is a street car, and ABS was deleted.
The spool time from a roll vac to +9PSI was 0.6 sec @ 60mph in 3'rd gear on a th400 3500 converter.
Took it apart to change to some higher quality turbos, I had ebay T3 turbos before, these are 96 AR T4 housings. Also added stuff like a cage and a huge radiator. Just minor upgrades
More pics will be up end of the week.
Old May 29, 2006 | 05:49 PM
Tiago's Avatar
I See 5 psi at 2500 rpms, positive pressure at about 2200... on a stock motor (twin T70s as well btw).
will be funn to see hwo they react on the new setup , shoudl be full boost in the low 3000s
