My thoughts about meth injection
Old May 31, 2006 | 02:56 PM
  #41
RW99's Avatar
I think the answer to the "cons" will depend on how the methanol is being used.
If you're running more timing to take advantage of the lower IAT and increased octane of an undiluted methanol spray, then there is a risk of going lean and consequent damage if the meth system fails. If the vehicle has been tuned with methanol, then it is likely that fuel has been removed to prevent going too rich as the alcohol is sprayed, so you're gonna be quite lean. If you have stock internals, maybe this is where they fail. On a forged motor, you might have more of a safety margin? Might depend if you are also running an effective intercooling setup, as far as the consequences of your lean condition.
If the car was tuned to run a safe WOT A/F on its own, and THEN a more modest spray of methanol was added, then I think it would be quite safe to use. That setup would not be taking full advantage of the methanol, however.
Perhaps the "middle of the road" solution is to be somewhere between the above setups; the car could be tuned without methanol so that it would go only "mildly" lean if the system failed... methanol spray could then be added to desired A/F while removing some of the fuel... and timing changes to take advantage of the methanol would be conservative.
Obviously, one thing that would help with any of these setups is to have a dependable indicator of successful spray... tracking IAT's live would be one way to go. But ideally you'd like to have a big frickin' red light that comes on if your system craps out and stops delivering the alcohol... and letting you know to get out of the throttle ASAP.
Old May 31, 2006 | 02:58 PM
  #42
Superman09's Avatar
LS1Tech Sponsor
huh im confused.... you add meth to gas tank? I thought it was set up a bit like nitrous and sprayed in threw the FMIC?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old May 31, 2006 | 03:05 PM
  #43
frcefed98's Avatar
Superman, you add another small tank for the meth, usually gallon tank. The meth feeds from this tank into a IC pipe into the TB.
I'm using my windshield washer tank for my meth tank.
J
Old May 31, 2006 | 03:33 PM
  #44
Superman09's Avatar
LS1Tech Sponsor
haha genious.... i never drive in bad weather to use that windshield crap anyway! Anyone have any input on the meth kit that STS offers?
__________________
Old May 31, 2006 | 03:36 PM
  #45
frcefed98's Avatar
Sure do..I have the STS meth kit and this is what David@STS sent me in regards to its features/operation
Meth kit straight out of the box setting from STS is set to kick on at @4psi. We wire it to the injector so it pulse sprays with the injectors sequence. 2 jets are included, M10 & M15. Typically the M10 will be more than enough for the LS1 and up to 550rwhp. The meth system is adjustable, meaning there are provisions in the wiring system to reset it, to kick on at a higher or lower psi setting. Tuneable meaning you can change the jets for morexor less flowxand tune your vehicle on the dyno with Meth.
Hope that helps
Old May 31, 2006 | 04:03 PM
  #46
Superman09's Avatar
LS1Tech Sponsor
oh dang, sound cool. ill have to pick that up with my STS purchase
__________________
Old May 31, 2006 | 06:05 PM
  #47
Camaro_Zach's Avatar
what systems are the best? what about this devilsown setup?
Old May 31, 2006 | 06:09 PM
  #48
SiDeWaYZz28's Avatar
alkycontrol.com Julio has a kit made speificly for f-bodys
Old May 31, 2006 | 06:17 PM
  #49
i dont see an fbody kit, just a tta and gn, yes i realize tta is an fbody, but im thinking ls1 based fbody since this is ls1tech. both of those are 3 bar setups, i have a 2 bar, will that still all work? and devilsown also has a specific 2 or 3 bar setup for ls1 based cars.
Old May 31, 2006 | 06:24 PM
  #50
give him a call
Old Jun 1, 2006 | 07:03 AM
  #51
KraZy's Avatar
I have his 4th gen fbody kit......its not on his website.
Old Jun 1, 2006 | 10:18 AM
  #52
fletchls1's Avatar
Looked at my invoice. Nozzel size is 600cc. From what I am hearing from others, that sounds like a big shot? I do not feel a power loss, but definetly an increase!
