Laminova intercoolers?
Brad Shantry, Product Development Manager of Wheel to Wheel Powertrain, said:
"The SEMA show was a great success and the supercharger drive system in particular was very well received. We are confident that it will prove popular within the performance industry owing to the significant boost to power and torque it gives to mid range engine speeds. This enhanced engine performance will be particularly useful on a medium size 4-wheel drive SUV."
Andrew
Andrew
It would be interesting to know why GM didn't use these in the LSA/LS9/LT4. They already had experience with the older Cadillac STSv and the Cobalt. I'm guessing it was a purely financial decision.
Andrew
edit - specific heat capacity and thermal conductivity is what I was refering to.
More pics until the link expires
https://www.ebay.com/itm/Vectorpro-l...p2047675.l2557
Andrew
To my knowledge, these have never been tested. The builder of them made one for a LSA blower and it was a huge failure. It hadnt been fitted, or tested. It didnt fit and it ran way hot and lost a ton of power from additional airflow issues
If your drag racing he car then an A2W will work better with Ice for the 1 min you need it to. For the street A2A. A lot of the Ford 302 guys and the New vettes have to upgrade there intercooler stuff bc of high IATs.
Now I run the same A2A but I’m turbo and no complaints, logs show 100-118* IAT temps in boost without the 50/50 activated yet.
Laminova cores have been used extensively in other markets with nothing but success. The cores are more expensive than traditional bar/plate and there is a bit of machine work required to build an intercooler with them. This one is 100% billet everything so obviously it will be really costly to produce. Most home brew intercoolers are flat plate with crude holes cut in them. The sleeves, raw tubing with slots crudely cut. The end caps have to be precisely machined, but the main assembly is often just cobbled together. It doesnt have to be perfect
Heres a TT LS1 with a 12 core home fab. IIRC, he used a hole saw to punch the ends, then a drill and jigsaw for the tube slots
